Question about ViewSonic VA721 17" LCD Monitor
For the color adjust on my view sonic VA 721 monitor, the red doesn't seem to work but the green and blue do. I purchased this monitor at a garage sale for not much so its not a big deal, it would just be nice not to have to buy another monitor.
  • 4,924 Answers
Just set the monitor on auto ..and it will adjust by itself..after that click right on the desktop ..than properties,,and after that settings in that window...here click advanced..and you will get some buttons on the top of the window..see which one s for the colors adjustments and complete the setting from here ..it is the image driver adjustment ..you can set the color management ..
also you can make thi sdirectly from the color settings in the image driver ..from clicking on the image icon on the tray of the task bar ..
Posted on Aug 30, 2010
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I am using view sonic VA 1703w, when i switched
if ur monitors warrenty over than open monitor try to fix LCD connecting wire to main panele
Jun 24, 2010 | Computers & Internet
The monitor has now got a blue tint I have checked the lead
Your monitor has a menu system that will allow you to access the color guns so you can adjust the red, blue, green guns that create the color picture.
The blue tint may indicate that you need to adjust teh reg and green to offset OR it may indicate that you have lost the red gun all together.
If this is an older monitor and you are considering repair... cost points say it is cheaper to buy a monitor ~$60 bucks
Oct 03, 2009 | Computers & Internet
No red colour in my lg lcd monitor ..red colour setting doesnt bring any change i screeen..pls suggest some solution
it is very simple, by default in monitor circuit RGB (Red, Green, Blue) tube is installed. and in combination of both of three colors we are able to view colorful image. due to non functionalty of Red color u r not able to view red color in screen, either you replace picture tube or purchase new monitor. coz cost of this tube is equal to monitor.
Jun 05, 2009 | LG Flatron F700P 17" CRT Monitor
Some green color patch in the middle of the screen
Looks like you have an LCD. I was guessing it may be magnetic related in which case I would recommend you degaussed your display using the degauss function but your monitor won't have it since it's not a CRT by the looks of it. I would recommend contacting your dealer or where you purchased the monitor at a retail store. Since it's only 8 months old, you may be able to return it under warranty. If your retail store doesn't let you do that, talk to View Sonic directly and see if you can RMA your product for returning to the manufacturer and receiving a new or repaired unit.
Check out Viewsonic's website for more information.
Mar 24, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Sony kp-57wv600
hola al problema lo debes tener en los transistores de color que estan en en la plaqueta donde va el socalo debes tener alguno desoldado
Sep 24, 2008 | Sony KP-57WV600 57" Rear Projection...
Samsung monitor and mac os
Please do not adjust RGB unless you know what you are doing.
For critical color work, you will need to use a photospectrometer and calibration software to analyze what your monitor is spitting out.
There are a million obvious reasons you should not trust your eye making arbitrary RGB adjustments off the hip.
Feb 15, 2008 | ViewSonic VX2255 Monitor
Colors are off after auto adjust
I seem to have found the solution (and the cause, perhaps?) for this problem!
I was having the EXACT same problem with a monitor I'm repairing for a friend. The capacitors on the power supply board were blown (CapXon capacitors, who'd've guessed), which was keeping it from powering up. After replacing the capacitors, the screen worked beautifully. But it had this weird yellow tint!
The strange part was that pure colors - red, green, blue - all appeared perfectly OK on screen. Curiously, the menus would show in the proper colors, except for one: the manual color adjustment menu, which illustrated "Blue" as a sort of off-green in the icon. Auto-Adjust would always fix the colors for a split second, then go back to yellow. Reset didn't fix it. Color reset didn't either. So, exactly the same problem as above.
The solution I found was hidden within the main menu itself, a sort of "easter egg". <b>Hold the Menu button down while pressing Power, and hold it down until the screen, and menu, appear</b>. There will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. Voila! PERFECT COLOR! Perhaps this menu was accessed by accident, and calibrated to an incorrect color key. But now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Hope this helps some people, it sure saved my ****! ;)
Dec 05, 2007 | AOpen 19" LCD
ViewSonic VA721 17" LCD Monitor Logo
110 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
