Question about HTC P3300 Smartphone
HTC P3300 GPS not showing correct location
I have a HTC 3300 and i am trying to use the GPS. The problem is that the device shows my Location on the map which is about 50 metres offset from my actual location. So far i have not found any setting which could correct this.
This is making the GPS useless for me. PLease Help !!!!
Thanks,
Suneel
  • 242 Answers
Most GPS systems have some inaccuracies.
The accuracy of you GPS system depends on your location, the number of satellites available on your location, if you are inside a building or in open field. Also standing between buildings increases inaccuracy.
So most of the time there is a deviation from your location. An inaccuracy of 30-50 meters is not xtremely bad for a GPS receiver in your phone.
Try to go to a place without buildings, trees close around you, best is to do this with a clear sky, and give the GPS receiver some time to find satellites and calculate it's position. Now the inaccuracy should be no more than about 20 meters.
I don't know the quality of the receiver in your HTC, but I think a accuracy of 20 meters should be possible.
Please post some feedback: where are you when you get inaccuracy of 50 meters? what's the inaccuracy when you are in open field?
Good luck
Posted on May 08, 2008
HTC 3300 PC SUIT DOWNLOAD
Thanks for using Fixya.
To download the PC SUIT for HTC p3300, visit this link and download the executable file. You will need to install it on your computer system.
Good luck and have a nice day.
Nov 06, 2010 | HTC P3300 Smartphone
In my htc p3300 smart phone they are showing align screen from 1 hour it is asking tap the target firmly and accurately at each location on the screen.
Remove the batrtery while the Phone is turned on.
Reinstart.
it will reload defaults
Rate this solution, Write a comment to keep in touch.
Sep 16, 2010 | HTC P3300 Smartphone
How can i connect HTC P3300 to pc with bluetooth
It's as simple as that.
1. Enable bluetooth on your HTC phone.
2. Tap 'Start' > 'Internet sharing'.
3. From the 'PC connection' drop-down list, seletec 'Bluetooth PAN.'
4. Tap 'Connect'.
5. Enable bluetooth on your computer/laptop.
6. Go to 'Conenction Manager'.
7. Select 'Conenct via bluetooth'.
Both devices will be in sync now enabling you transfer data.
Oct 18, 2009 | HTC P3300 Smartphone
How can i update my htc p3300
The two software items which you get updates are the 'Windows MobileOS' and the 'Quck GPS', if your have subscribed to GPRS from your GSM service provider. The QuickGPS update can be obtained after pressing the left-bottom key (or Program>QuickGPS) and follow instructions as displayed on your 3300. The other update is from Settings>system>WindowsUpdate
Sep 13, 2009 | HTC P3300 Smartphone
How can i connect internet on my pc with htc 3300
The p3300 connects to the internet via Wi-Fi, GPRS or mobile phone network. Start with Settings>Connections>Connections and make your choice. you would need access and password information as well as private network information handy
Aug 21, 2009 | HTC P3300 Smartphone
I want to use GPS connection am using HTC 3300 Windose mobile please help me
all u hav to do is to install mapking frm bundled cd n it will ask for key which iz given on the card of ur registered mapking software
Jan 24, 2009 | HTC P3300 Smartphone
Gps not working in p3300
HEY BUDDY THOW THAT AND GET A NEW PHONE
Jan 06, 2009 | HTC P3300 Smartphone
Cannot find slot location to replace storage card
The memory card slot is a tiny slot below the battery.
1.Remove the back cover of the HTC
2.Remove the battery
3.You would be able to the card slot on the lower left corner of the device.
Thanks
Mandeep
Jun 04, 2008 | HTC P3300 Smartphone
Can i connect with HTC P-3300 to Laptop
tray too change activsync use 4.5 if this dont work change room from yours pda mail me jhonyvyrus@yahoo.com
Mar 31, 2008 | HTC P3300 Smartphone
Not able to set up GPS in my HTC p3300 in india
It sounds like your not able to access the internet on the device , try going to a normal webpage and then you can check if it loads it most probably wont. if that is the case you will need to contact your network to get the settings. ( Most networks will brand the device with there own name it can be helpful to find what this is before calling .) once you have done this then you will be able to download the quick gps settings . The special GPRS mentioned above is only the networks name for there GPRS service.
After this is done you may notice that you still arent able to use your GPS to find your location that is because you need to select the port that the GPS device is on
1.Tap start > settings
2. Tap the system tab
3. Select the GPS option
4. In the drop-down box that is entitled GPS program port select COM4
5. Tap Hardware tab , Gps hardware port should be ( None ) and baud rate 4800
6. Tap access tab and then select manage GPS automatically tickbox
7. Now click ok then x
You will now need to setup MAPKing to use COM port 4 as the GPS device this will now allow you to use your GPS properly
Feb 18, 2008 | HTC P3300 Smartphone
HTC P3300 Smartphone Logo
134 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
