Question about Dryers
I have an LG DLG0332W gas dryer and it not getting hot. Read that the thermostat my need to be reset. have the dryer torn apart and I am having trouble locating the thermostat reset button. Where is it?
  • Dryers Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Aug 30, 2010
LG DRYER DLG0332W GAS
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[[]
Aug 05, 2011 | LG DLE0332 Gas Dryer
Hi: I have a LG DLG0332W Dryer, which is running but drying. I cleared all the lint areas still nothing. Is there anything I can do, I am pretty handy. Thank You.
on the right side there is an access panel, unplug dryer, open it up and look inside you will see two wires and in the middle is a reset button, push it in and it shall dry
Feb 27, 2011 | LG DLG5932W Gas Dryer
Everything seams to work but the heat will not come on the igniter will not come on gas will not come on . HELP this is a LG DLG0332w model
The ignitor may have failed, and you will need a multimeter to test it. If you do not have a multimeter, you can replace the ignitor in the chance that it is bad
Jul 04, 2009 | LG Dryers
Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Mar 01, 2009 | LG DLE2532W Electric Dryer
Dryer won't heat
Hello thecrow124,
Your problem could be one of a few things... you may have a thermal cut off switch that has opened and needs to be replaced. Once they open ( like a fuse) they are non-resettable and will need to be changed. That would disable the flow of gas to the burner and not allow your dryer to heat up. You may also have a bad igniter so don't rule that out. If you are inclined to diagnose this yourself, please do so with power and gas disabled and use caution when working inside the dryer. I am attaching a link for the service manual to aid in trouble-shooting your system Please notice the component testing section from Page 10 and up. That should provide sufficient information to diagnose a bad device and get you started.
http://136.166.4.200/contents/Laundry/DLG0332/DLG0332_Service_Manual.pdf <--manual
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx <--parts
Let me know if I can assist you with your diagnostics... Please be careful !
Regards,
Rick
Nov 24, 2008 | LG DLE2532W Electric Dryer
Not properly drying
If you remove the front cover hitting the reset switch is rather easy. However I did that the other day and only got 1 load done before it tripped again.
I just picked this dryer up used from a buddy the other day and am already having trouble. Also... It runs very loud. How loud is yours complared to the washer?
May 30, 2008 | LG DLE0332 Gas Dryer
LG DRYER DLG2532W GAS
Dryer doesn't get hot. Replaced all the sensors and still it doesn't get hot. Doesn't get hot in any mode. All vents are clear. I'm thinking that maybe there may not gas getting ignited, but I know nothing about gas stuff and am not sure if thats the problem. Any ideas of what I should be looking at next?
May 15, 2008 | LG DLG2532 Gas Dryer
Dryers Logo
691 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
