Question about Yamaha RX-V659 Receiver
What do i hook the sub woofer to - Yamaha RX-V659 Receiver
    President:
  • 1,285 Answers
The sub woofer speaker should be connected to the Center, the main speakers should be set to the front and the secondary ones in the rear....(front = main just in case surround is not on, center = is for that ump / boom sound, rear = that just pass you by (make you look behind yourself)
Posted on Aug 30, 2010
Trying to hook up a KLH sub woofer, S100ETH, PSW8-100 to a VCR reciever. Reciever has sub woofer connection but does not works on the KLH sub woofer. What is the problem ?
I suggest you go over your receiver set-up instructions. See if you need to set the receiver to acknolwedge the addition of the subwoofer. It should be in your receiver set-up steps. Just as a check, hook up one of your other speakers to the subwoofer lead to see if gets audio signal. I'm guessing the issue is your receiver settings.
Jan 06, 2015 | KLH Audio Players & Recorders
Need sub woofer
Any powered sub woofer will work. Just hook it up to the sub pre out with an RCA Cable.
Aug 02, 2012 | Aiwa AV-D57 Receiver
How to hookup
hi,
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
ok
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
Sub woofer
You are suppose to hook subs up to a amp.
May 04, 2010 | Car Audio & Video
Cerwin vega passive subwoofer model sw-12b
Passive woofers are hooked up to the output of a sub amp.
Active woofers are hooked up to the sub out of a receiver. They have the amp built in.
Mar 09, 2010 | Cerwin Vega Audio Players & Recorders
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Sub
Most amplified sub woofers need to be grounded to the output source.If you plug the sub woofer in to the receiver you would use a ground wire from the receiver to the sub woofer there should be a ground terminal on the sub woofer and receiver.
Feb 17, 2008 | JVC RX-778V
Open Questions:
See all Yamaha RX-V659 Receiver Questions
Yamaha RX-V659 Receiver Logo
126 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
