Question about Kato N Scale Sd80mac Locomotive (conrail) [1765501]
I need 923150 rear coupler for my SD80MAC in N scale. No one has one, noteven Kato.
Is there a parts list?
Parts Catalog : Bachmann Trains Online Store!
estore.bachmanntrains.com/index.php?main_page=index&cPath=66
Please browse by scale and model. If you can't find what you need, contact our PartsDepartment for more information. Bachmann's Parts & Service Departments ...‎HO Parts - ‎N Parts - ‎Large Scale Parts - ‎On30 Parts
Model Train Couplers / Trucks - Hobbylinc.com
www.hobbylinc.com/model-train-couplers-trucks
Discount pricing on couplers - ho, trucks - ho, misc parts, trucks - n, couplers - n, and trucks - g. ... 1-20 of 1,476 results in Model Trains > Parts. ... +Wish-List.
HO Scale Parts - Atlas
www.atlasrr.com/hoparts.htm
We are in the process of converting all of our parts diagrams for locomotives and freight ... If you do not see a loco or freight car on this list that you are interested in, ...Atlas Production Schedule. Track. HO Models. N Models. Parts. Beginners.
Train Repair Parts Home Page - Hobby Surplus
www.hobbysurplus.com/trainrepairparts.htm
Come to Middletown or New Britain Connecticut and visit our huge Toy and Hobby stores. ... Example of an"Exploded View" from a train repair manual ... operators and collectors have correctly identifying the parts required to repair their trains, ...
Brasseur Electric Trains - Over 12,000 Model Train Parts ...
www.brasseurelectrictrains.com/service/catalog.asp
Jan 04, 2016 | Crafts & Hobbies
Where would I find a kato 10704-1 parts list?
www.katousa.com/faq/repair.html
Try here, not sure.
Jun 16, 2014 | Kato Toys
Rear motored truck on kato ho p42 after dcc installation not working properly after period of time
I've had the same issue. I doubt it's your DCC hookup. Those motors are probably shot, and need to be replaced. I run analog, and I've had multiple motor failures with these things. These motors don't last long and, when one goes, the other one often follows... fairly soon after. I was able to prolong the motor life a little bit by orienting the motors to run the same direction. (I turned the rear truck around. I realize that's probably not possible, with your DCC in place.) I've still had motors fail, in spite of motor orientation. I've got all nine units, and six of the nine have had to have motors replaced. Some units, I've had to replace motors more than once! I haven't figured out any way to bring a motor back to life, once it starts stalling intermittently, or if it quits altogether. Sometimes, rotating the motor a tiny bit in its cradle might help, but that's a stop-gap. I suspect motor failure... unrelated to the DCC hookup.
Feb 04, 2014 | Kato HO P42 Genesis AMT PhVb 161
Locomotive moves then stops
If your locomotive continuously starts then stops, when prodded with hand/finger repeats process. Then most likely, first check your electric connection for a loose connection. If everything looks ok, check wheels on locomotive for dirty wheels, then check track for dirty track.
Nov 10, 2013 | Kato N Scale, Amtrak P42 Superliner Train...
HELP!!! I need to lubricate a KATO N scale
Be sure you use a FINE needlepoint oiler, that will let out a single very small drop at a time. I use a "Trumpet Alve Oil" which is very thin. (Or I mix it with a 3-in1 oil to thin it. Never tried the sythetic oils, but should be ok, if not too thick.
Oil: any point where a spinning shaft end touches a bearing or seat, or passes thru a support, and a drop on the gear teeth if any.
DO NOT oil any part of the motor, as this could get into the brushes. Be brave, and best of luck.
Jan 23, 2010 | Toys
Kato locomotive doesnt run. Goes for a short time with spray of contact cleaner then stops
That means that your track is dirty. Your locomotive is picking up dirt from the track, which builds up. on the wheels. Use a track cleaner NOT alcohol... the alcohol does leave a residue on the track after it dries.
Jan 10, 2010 | Kato N Scale, Amtrak P42 Superliner Train...
Kato N Scale Sd80mac Locomotive (conrail) [1765501] Logo
59 people viewed this question
Top Kato Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Kato Craft and Hobby Expert? Answer questions, earn points and help others
