Question about Canon PIXMA MP160 All-In-One InkJet Printer
Printer not responding
Its just like the one on my screen where is notepad
    Guru:
  • 377 Answers
Hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Posted on Jun 14, 2008
My touch screen stopped working on my samsung impression so i put the rest code in and the phone reset then its now stuck on the calibration screen and the touch screen wont respond
Dont kno if "Impression" is similar to "Omnia" but 'REMOTE SCREEN ALIGNMENT' program installed on PC skips 'align screen' on your phone. Also "welcome.not" (made in notepad) & pasted into your root files. A REGISTRY EDITOR will allow you to input the touchscreen configuration numbers manually. Of course, none of these will be much good if you dont have 'Windows" phone or cant access your Registry!!
If all this fails, ASK 'XDA DEVELOPERS', or 'MoDaCo'.
Oct 29, 2010 | Samsung SGH-A877 Impression Cell Phone
The "dot" does not responds on my keyboard I cant close my sentences
try with typign the dots in other place like word or notepad and see it it typing or not if it is not then you need to replce the keyboard or if you want to use it the dots button you can use on screen keyboard by typing OSK in run window it will show you on screen keyboard . you can use that .
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | Acer NSK8458AN Keyboard
Hi, I need some help in scanning a note pad document. The screen says to update the LCD screen. Can you walk me thru this?
Why would you scan a notepad document that isd already in you computer?  Anyway/ make and model of printer/scanner?
Jan 19, 2009 | Office Equipment & Supplies
Printer will not work
if the printer is new use the disc that came with it
if it is old --scan canon web site to get a download of the printer as they will have it where as the operating system may be too new and it drops off older models
Mar 24, 2017 | Canon i450 - Printer - color - ink-jet -...
Pixma IP3000 will not print
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Sep 16, 2008 | Office Equipment & Supplies
Printer will not print
And.....
How about telling is what the make and model of the printer, what operating system you have, any error messages that pop up etc etc etc
HP Laserjet 3050, 2605dn, 1022n
One time un reinstall the all printer drivers Before u go to C:\WINDOWS\system32\spool\drivers\w32x86.then delete all folders and files
Apr 08, 2008 | HP LaserJet 3050 All-In-One Printer
Printer Canon Mp160
  1. Go to notepad
  2. click File, then Print
  3. in the dialog box that appears, click Properties
  4. click the maintenence tab
  5. find print head alignment
hope this helps
Apr 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer installation
Hi Nibber,
There is no need to install the printer software in Windows Vista.
You have built in drivers for most of the HP printers in Vista.
Just connect the printer and restart the PC.
Make sure that you are in Administrative mode.
You should not be in Guest Account or Limited User Account.
Try to print from Notepad
Press and Hold Windows key + R
You will see a Run box.
In the Run box type notepad and press enter.
This will open Notepad.
Type some lines and click on file
Print
Else try these steps.
Click on start >> Printer and Faxes >> Click on Add a printer >> Next >> Select Local printer and click on next >> Find printer in the directory >> Next >> Find printer Now >> Select your printer and click on Next >> Next >> finish
Then try printing
Mar 21, 2008 | Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
121 people viewed this question
old marine
old marine
