Question about Zebra S4M Thermal Label Printer
Printing every third labels, not every one
I use zebra S4M and i have problem now. Printer print not every labels, but every third. I do not know what is it.I use BarTender and BarOne and it is the same. I uninstall printer, install again and nothing help. Pls,help me.
Go into the web interface of the printer and set the Calibration to SHORT CAL on power(media) up and head down. It worked for me. Now everytime the printer is rebooted it spits out a few labels(to calibrate) but then it works properly.
Posted on Dec 03, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Zebra Master
  • 1,362 Answers
If you push the foward button does it skip several labels, instead of stopping at the next one?
Did someone change the roll or type of label? if no
then your problem may be a simple one.
look under the label you should see a green tab. actually there are two one that guides the paper and one under, the one under slides back and forth. Now depending on if you have a lbel with a seperation in between each one or the one that have knotches on the side, you need to position the sliding sensor accordingly,
If seperated then it needs to be towards the middle if a knotch then towards the back of the printer. as you adjust keep hitting the forward button until it only moves one label at a time.
If it doesn't work then you may need to recalibrate. Let me know.
Posted on May 08, 2008
S4m quick books
change the default orientation setting in printer properties.
May 10, 2013 | Zebra S4M Thermal Label Printer
Is there a way to change the setting on the Zebra S4M to rotate the print 180 degrees to match our labels?
No. The change must be made in the software that you are creating the label design in. Let me know if this helps!
Jun 21, 2011 | Zebra S4M Thermal Label Printer
Hi I am unable to print from Zebra S4M.. while printing the configuration it prints but does not print the test page or the label.
There a number of things that can cause that: 1) wrong printer driver was installed 2) cable to printer is faulty 3) wrong port was selected when the printer driver was installed
Check these and let me know!
Jan 20, 2011 | Zebra S4M Thermal Label Printer
Loaded ribbon correctly according to Zebra S4M Quick Reference guide....but won't print anything on labels.
The ribbon has wax just on one side. So, if nothing prints on the label, first thing I'd check if the ribbon loaded with waxed side facing label.
Jan 11, 2011 | Zebra S4M Thermal Label Printer
Zebra S4M label printer
i think it's a GAP problem, try to calibrate from the computer, if that's not solve the problem, find the CALIBRATE option on the LCD panel a. just follow the instruction to do manual calibrate
Aug 13, 2009 | Zebra S4M Thermal Label Printer
S4M doesn´t print
The S4M comes with either EPL or ZPL programming language installed. (installed at factory) The S600 is a ZPL only printer. Check that you have correctly specified the S4M as a ZPL printer. Print a config label to check. If it is set as an EPL printer contact your supplier and ask him to download the correct programming language. It should only take a competent engineer about ten minutes (If he knows what he is doing)
Jan 20, 2009 | Zebra S4M Thermal Label Printer
S4m is not printing
zebra s4m barcode printer ,suppose if i print 10 Labels only 2 Label come out balance 8 in memory .then printer comes pause, disply showing paper out /ribbon in/please help me....
Dec 30, 2008 | Zebra S4M Thermal Label Printer
Printing every third labels ---> not every one:(
Sounds like the label height is set too high. Go into Printer Preferences in Windows and change the height dimension to match the size of the label you are using.
May 08, 2008 | Zebra S4M Thermal Label Printer
Printing every third labels ---> not evry
You need to take the labels out.
If you are using the labels that have perforations is where you can tear them off.
What you need to do is to
1) Switch off printer
2) ensure that the ribbon is loaded correctly
3) take some labels, feed them through the mechanism till you can see them coming out from the other end.
4) Make sure that the labels are lined up with the alignment mark or sometimes with label printers there is a light.
5)switch on printer and do a test print
Zebra S4M Thermal Label Printer Logo
282 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
