Question about Kitchen Ranges
Oven Glow Bar does not light,and I have power
  • 530 Answers
Does the broiler work? if yes you have a bad ignitor if it's gas.
Posted on Aug 30, 2010
Oven shut off and won't re-light
defective glow bar or bad safty valve. But if the glow bar does not light at all, most likely it will be a bad glow bar
Jul 09, 2014 | Summit WNM4307KW 36" Freestanding Gas...
Kenmore Oven
I am sure you will just have to replace the oven igniter (glow bar) These will crack and not let any power through the oven valve.
Nov 27, 2013 | Magic Chef Ovens
I smell gas when I turn on my oven. I replaced the gas line but have the same result.
Your Maytag wall oven is equipped with
pilotless ignition. Heat from the Glow Bar
ignitor lights the oven burner. With this type of
ignition system, the oven will not operate
during a power failure or if the wall oven is
disconnected from the wall outlet.
if it is plugged in and everything, your glow bar may be broken, which would mean you will either need to replace it, or get professional service.
Dec 25, 2010 | Maytag CWG3100A Gas Single Oven
Kenmore gas oven 362.7163191 wont light, what could be the problem ?
The glow bar ignitor in the oven is going bad. Remove the oven racks. Remove the base pan in the oven. This gives you access to the glow bar.
Turn the gas off to the oven. Place a clamp on amp meter on one wire of the ignitor and turn the oven on to Bake. If the amp draw is 3.2 or less,replace the glow bar ignitor.
Nov 22, 2009 | Kenmore Ovens
Lights once then not again
Hot Surface ('Glow Bar') Ignition System glow-amin.60x20.gif (most common)
This is the most popular system currently in use and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve. What happens in this style control system is that the thermostat or electronic control supplies power to the oven ignitor and gas valve which are connected in series (one after the other). As power flows through the ignitor it heats and allows a specific amount of current to flow to the oven valve which is in the same circuit. If the oven valve senses the proper current flow, it opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it.
Jul 20, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas oven will wil light
Check the glow bar ignitor in the oven.
Does it come on and glow brightly.
If not, replace the glow bar.
Mar 08, 2009 | Magic Chef Kitchen Ranges
Kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Magic chef oven igniter will not glow.
the gas vavle..check for contiunity..just follow oven ignitor wire down ..onthejob
Jan 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Gas stove
The JGRP17 (not a full model number) does not have a pilot light. It uses glow bar ignitors. Watch the burner at the top of your oven when you turn on broil. After a short time the glow bar ignitor begins to glow, and a short time after that the broiler burner should ignite. The same thing should happen with the oven burner under the floor of the oven when you attempt to bake. If the igniter does not glow, or glows and burner does not light, replace ignitor. (looks like part # WB2X9154)
Sep 04, 2008 | GE JGRP17 Gas Single Oven
Kitchen Ranges Logo
53 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
