Question about EliteGroup P4VXASD (P4VXASD-R) Motherboard
Method set up when I change from sdram is DDR. Thank.
Benimur
  • 6966 Answers
SOURCE: DDR PC3200 displays no video on LCD and Out of Range on CRT
Hi, If I may add to the other posts, 1. If the problem persist with the new or the old memory, then it is not a memory problem; 2. Jumper on Clear CMOS/BIOS and removing the small battery should set the system back to default, of course for normal operation, it should be set back to normal position; 3. It is possible that it is not a PSU problem, it is likely that the PSU is ok and just doing its job of switching off probably due to a fault at the motherboard; 4. The MB fault maybe be anything. Try removing everything except mb & front panel wires and the psu (video card,cables to your drives, memories). Check if on powerup, fans will spin normally and not just start then stops; if it works reinstall everything, if not: 4.1 Remove your motherboard from the back panel plate, remove the front panel connector/wires (it is a good idea to mark them down or copy how they are connected), remove power supply. Place mb on top of an old newspaper or something (as long as not metal or conductive), Install PSU power connectors, short/jump power on pins (where the front panel connectors/wires were connected before). If it works, your set to go, If not, maybe for some unknown reasons the mb is fried. Other possible causes of start/stop spin of fan: reset switch stuck, bent pins in memory slot, inverted IDE cable (though not likely but possibly), MB sensing fan is not or malfunctioning, fried CPU, BIOS (though normally there is a warning of boot block or something like that), no keyboard present. Of course, I am assuming that you have replaced the PSU with a new or known good one as you have comment/posted previous to this. Hope this works out for you and give you further ideas. Pls comment/post back should you need further information. Good luck and kind regards.
Posted on Aug 12, 2007
eagle338
  • 4889 Answers
SOURCE: ECS M925 1.0 sdramm to ddr memory
The normal DDR Ram is supported..It doesn't support DDR2..
Posted on Nov 03, 2007
  • 119 Answers
SOURCE: IS DDR SDRAM IS DDR II RAM OR DDR
No. DDR replaced the SD in RAM so SDRAM and DDR RAM are two completely different things but each ram type has its own frequency hence you get SDRAM 100(mhz) and SDRAM 133(Mhz) just like you get DDR 1 RAM at 266(mhz) and 400(mhz) and DDR 2 RAM at 533(mhz) and 800(mhz). Therefore as you can see how these things differ, but if your mboard takes SDRAM that it can take and frequency of SDRAM but you must ensure that all the frequencies of all your RAM modules in all your slots correspond otherwise you will have problems, meaning that if you decide to use 133mhz RAM then all your RAM modules that you use must be the same. Let me know how you go. thanks
regards
Posted on Feb 06, 2008
SOURCE: ddr not detected
if you want to use ddr ram with p4vmm2 mother bord you must replace the jumper near by the ddr2 slot
then your computer starts to work with ddr ram at 266Mhz also 400 Mhz too.
Posted on Feb 09, 2009
  • 218 Answers
SOURCE: Upgrade PCChips M925
According to PCChips, the maximum CPU & memory supported for all three is the Intel P4 Northwood (HT) 3.06 GHz 512K,533FSB,Socket 478 and 2GB (2 x 1GB) DDR 266.
Be sure you have the latest BIOS version for your motherbaord.
M925ALU (V7.3) must have BIOS : 030703s
M925G (V8.0) and M925G (V9.1b) must have BIOS : 050510s
Hope this helps you out.
Posted on Jan 10, 2010
Testimonial: "Clear data to upgrade my PC. Thanks"
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
How to install additional 256 MB memory
You simply just push the memory into the DIMM socket on the motherboard. You need to use DDR SDRAM but should check what your I/O bus speed is set at. They make 4 different types of DDR SDRAM. They are DDR-200 (PC1600). DDR-266 (PC2100). DDR-333 (PC2700) and DDR-400 (PC3200). The following links should help you out:
http://www.tech-faq.com/unbuffered-memory.shtml
http://en.wikipedia.org/wiki/DDR_SDRAM
Mar 20, 2009 | EliteGroup P4VMM2 Motherboard
Compatible memory for P4M266A-8233
Hi!
No you can not!
This is what memosticks that mobo of yours supports
DDR 200/266
PC100/133 SDRAM
Max. Memory 4.0GB
Good luck
Nic
Mar 09, 2009 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
I want to know if SDRAM and DDR@ are the same thing?
No SDRAM is single data ram, with 2 slots in the bottom and DDR is double data ram, with one slot at the bottom.
Aug 17, 2008 | Computers & Internet
DDR SLOTS INSTEAD OF SDRAM
Hello
Betwin the two couples of memory soket it must be ajumper that guives you the abilitie to change over the frequency rate when you change your memory model .
If there is no jumper try to check if they are not using a strap soldered in the mother board then you will need some electronic skills to change over your frequency
Apr 05, 2008 | Intel Motherboard
Want to upgrade the memory, ident. issues for proper DDR...
Hello!
as i look at your mainboard here: http://www.msicomputer.com/product/p_spec.asp?model=865PE_Neo3-F the mainboard support,
Supports four unbuffered DIMM of 2.5 Volt DDR SDRAM
• Supports up to 4GB memory size without ECC • Supports Dual channel DDR266/333/400MHz and up.
to be safe i would recommend DDR 400-
either buy 2 units 1gig -DDR400
Just say.."2 units 1gig Memory DDR 400 sdram "
may this help,
fixya, melnavz
Feb 26, 2008 | MSI 865PE Neo3-FS Motherboard
Nov 03, 2007 | PC Chips (M925G) Motherboard
P4VMM2 Motherboard problems with RAM Cards changing fron SDRAM to DDR
Depending on your version of motherboard, it may only take ddr when you change the motherboard jumpers, as i assume you have 2 SDRAM and 2 DDR slots, but you will need to refer to your manual
Apr 10, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup P4VXASD (P4VXASD-R) Motherboard Logo
18 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
