Question about Bosch 12" Compound Miter Saw 3912
How do you change the blade for a black and decker miter saw 7715?
  • 313 Answers
SOURCE: black and decker coumpound miter saw fence
check out toolpartsdirect.com for parts
Posted on Jun 03, 2008
rowdy45176
  • 2176 Answers
SOURCE: Lower Blade Guard on a Miter saw
If you haven't fixed them yet, give me the model and brand and I will see what I can do. Dave
Posted on Dec 24, 2008
picatudo
  • 239 Answers
SOURCE: changed delta saw blade
it turns the other way, to the right!
Posted on Feb 07, 2009
MarineTech1
  • 76 Answers
SOURCE: Have an old Black and Decker 7321 Skill Saw.
With the saw UNPLUGGED, check around the base of the motor shaft, there should be some kind of button that you can depress to lock the blade from turning. Then with the appropriate sized wrench, turn the blade locking bolt clockwise (it is a backward thread) to loosen it. Then simply remove the washers, etc carefully and replace them the same way they came off. If there is no locking button, you can use a scrap piece of wood on the saw table and push down on the blade to lock it in place.
Posted on Aug 10, 2009
  • 384 Answers
SOURCE: How Do You raise the blade on a miter saw to get
Lift the Handle.
Posted on Aug 31, 2009
Need to replace a miter saw blade on Black & Decker saw
If you don't have a manual, you can contact Dewalt, and they will get you one or help you. UNPLUG THE SAW!! , if your saw has a blade lock, engage it, if it doesn't hold the saw firmly on a scrap piece of wood. Then use the correct wrench and loosen the retaining nut. Take the nut off, remove the blade
Feb 24, 2014 | Black & Decker Saws
Broken lock bolt for the saw blade left hand thred iv,e got the old one out but need a new one ???
RYOBI IS ONE OF THE CHEAPEST BRANDS OF TOOLS YOU CAN BUY.Right next to Black & Decker. You probably won't find one at a local hardware store. Go to Ryobi . com.
Jun 05, 2011 | Ryobi 10 In Miter Saw With Laser
I have an older model black and decker miter saw. How do you change the blade? I can't seem to stop the motor shaft from turning in order to loosen the nut to remove the blade?
Hi, you need to look thoroughly at the casing of the electric motor. Somewhere between the motor and the gearbox is the brake which must be depressed in order to stop the motor from turning. If for some reason you cannot find this brake, use a pair of vise grips and clamp down on the inside of the blade and turn it until it stops. Now you can unbolt you blade. P.S. make sure you know if the thread is reverse or not! Good luck.
Nov 16, 2010 | Black & Decker 12" Dbl Bevel Miter Saw
Where can i find a users manual for a black & decker miter saw 1710. manualsonline does not have it.
I found an online manual. I hope it's what you are looking for.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/387479-00,1710.pdf
Mar 09, 2010 | Black & Decker DW713 10 In. In. Comp Miter...
Have an old Black and Decker 7321 Skill Saw. Bought it used. Cant figure out how to change the blade. Help
Aug 08, 2009 | Bosch 12" Dual - Bevel Compound Miter Saw...
I need to know how to change the blade on a Black and Decker 1710 Type 2 10'' Miter Saw.
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in the model number 1710 and it will go to another page requesting either a breakdown or instruction manual, you have to use the manual for a type 4. They do not offer the type 2 as an online version. Hope this helps
Mar 30, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Bosch 12" Compound Miter Saw 3912 Logo
Top Bosch Saws Experts
Tim Venetis
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
