Question about Microsoft Windows 98 for PC
Unable to find PCs in a network from a WINDOWS 98 PC
When i try to ping any other PC on a network its pinging but when i try to find a PC in the network search shows no PCs found.
  • 1,031 Answers
Restart the system and check again
Posted on May 08, 2008
Sound driver is problem
2 Suggested Answers
stif_NEC
  • 441 Answers
SOURCE: Unable to find PCs in network from a Windows98 PC
Try this:
1.click start>run>type \\IP of the other computer
Posted on May 07, 2008
Disable network password
do you get any error messages? open cmd from another computer and ping the pc in question (assuming this pc gets an ip). if "ping" works then try net view \\computer name or ip. you should be able to see the shares or get an access denied usually 5.
Try that and let me know what you got so that i might understand the root of the problem.
Jul 13, 2014 | Computers & Internet
Slow ping time
Ping depends on the server network and not the configuration of the laptop.If the ping varies, you need to check the network configuration.
Any further help, let me know.
Thanks for using "Fixya".
Jun 17, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Cant ping on a same network
the information you give sounds like your trying to set up a network, if this is the case you will need to set up the network in the netwok program on your computer....icon found in control pannel or on start menu ....shia
May 22, 2009 | Intel Computers & Internet
The printer can not be ping from the network PCs
try assigning a different IP to it and see if it can be ping afterwards. If the same thing happens even with different IP, chances are, its NIC is defective and needs to be replaced.
Feb 17, 2009 | HP LaserJet 4350 Printer
Try this:
May 07, 2008 | Microsoft Windows 98 for PC
Cannot access PageScope Web Connection in client PC
first try to ping this address, to see that this pc finds printer. you have to check network settings for that pc
Apr 20, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
WAP54G bricked power led blinking LAN connection shows as not connected
you did not specify where the wap is connected when you pinged it. Try this, connect the wap54g to your pc. Assign static ip 192.168.1.5 on the lan of the pc, then ping 192.168.1.245. if you can ping you should be able to access the configuration page. if the power is still blinking you can upgrade the firmware
Mar 10, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
HP 9040n NOT RESPONDING
Try connecting this printer to a different network wall point in the building. If still no change then move back to original wall point and try changing the connection at the Switch end in the comms room.
If still having problems then try pinging the printer to see if it gives time out or execessively high pings. Got a PC on the network and in windows open a "command" prompt and type ping -t XXX.XXX.XXX.XXX where the address of the printer should be place of the x's.
If linux open a console and type the same thing ping -t XXX.XXX.XXX.XXX.
Regards
Please dont forget to rate!
Regards
Feb 28, 2008 | HP LaserJet 9040n Printer
Why do we always have to click repair
What the repair option does is more or less disable and then enable the network connection to refresh the systems settings. This article explains what exactly it does: http://www2.lut.fi/atk/palvelut/PCTUKI/Windows/XP/Repair_NetWork_Conn.html ? Attempts to renew the DHCP lease, if the connection obtains its IP address through DHCP, using a broadcast message. ? Flushes the Address Resolution Protocol (ARP) cache using the command arp -d * ? Flushes the NetBIOS cache using the command nbtstat -R ? Flushes the DNS cache using the command ipconfig /flushdns ? Reregisters the NetBIOS name and IP address with WINS using the command nbtstat -RR ? Reregisters the computer name and IP address with DNS using the command ipconfig /registerdns So if this is what is being done, lets try to trouble shoot each symptom and see what resolves it. My first inclination would be to check your DHCP scope on your server, and see if your scope is running out of space. Also check the lease length and see if it is set to a small amoutn of time. Your PCs could be losing their IP addresses and thus need to get new ones all the time. Are you pinging by IP or name. I would do most of the ping tests by IP as that would remove any of the name resolution issues you may be encountering. Is the wireless brindge doing any type of mac-address or arp filtering? Also, can machines in the extension always ping each other constantly? This would help narrow down the problem to see if it is an IP problem on the hosts or a possible network equipment issue.
Sep 21, 2006 | HP Broadcom NetXtreme 10/100/1000 Network...
Microsoft Windows 98 for PC Logo
27 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
