Question about Kitchen Ranges
Pump runs for about 1 min builds up pressure then 15 mins later with no water being used the pump looses all pressure and starts up again. I installed a check valve in the supply line and this did not inprove anything
  • Kitchen Ranges Master
  • 43,501 Answers
You need a check valve in the suction line...
heatman101
Posted on Aug 30, 2010
1998 f250 5.4l would not start. changed feul pump and filter still would not start. 20 mni later started. was cleaning engine while running 10 15 min later died wont start.
Check fuel pressure at the injector rail. Could be your fuel pump relay is cutting out. If fuel pressure is good, check for sparks at the plug wires. Read the link below for more info.
Do It Yourself Diagnosis and Repair
Jul 26, 2017 | Cars & Trucks
Engine shuts off after driving 45 min when parking in reverse.But 15 min before this engine and slippery road icon comes on.2 hrs later car starts and drives normal then shuts off again 45 min later.
most commonly found problem relates to an electronic component heating up and shutting down. Have you checked to confirm there is fuel pressure when the vehicle shuts off. Is the check engine light on. Have you checked codes ? I suggest hooking up a fuel pressure gauge and letting vehicle run till it shuts off while monitoring the fuel pressure. If you loose fuel pressure, next step is to confirm there power going to the pump, if there is power going to the pump with no fuel pressure replace pump. Another suggestion would be to check for spark when vehicle stops running to eliminate an ignition problem. good luck
Aug 17, 2015 | 2008 Toyota Highlander
I have 97 Pontiac sun fire runs for 15 min then die will not start for about 15min after that
Fuel pump going out. Once it gets warm after 15 mins the o rings loosen up and cause it to loose prime and shut off. After cooling for 15 mins they have shrunk enough to build pressure again.
Feb 20, 2015 | 1997 Pontiac Sunfire
Runs min shuts off
Sounds like a fuel pump failure
Check for Codes
Check Fuel Pressure,listen for pump at the tank
Check for Spark or Injector Pulse
Check Battery Voltage & Alternator Output
Your loosing one of them or other things
Aug 29, 2013 | Ford Cars & Trucks
I have a 2003 lincoln ls it keeps running hot I replaced thermostat, radiator cap, water pump,and had lines drained. After replacing water pump and thermostat car ran fine for a month I went and got an ol...
Suspect you have a loose clamp on a radiator hose or the oil change guy made something leak. There is a tool which is similar to a a bicycle pump in that it pressurizes the water system and your engine does not have to run or be hot to test. Some major auto parts stores may have a loaner.
Its going to stay hot and lose pressure until you fix the leak.
Jun 29, 2017 | Lincoln LS Cars & Trucks
Hard to start after sit for 15 to 20 min. have changed fuel pump & all sencers that can think of acts like its loosing the fuel to me but not sure?
you need to check the fuel pressure, running it should be around 50psi. and after shutting down try to start, fuel pressure should jump to 50 psi within 1-2 seconds. if it has to build up you have fuel bleeding down somewhere. I have run into dirty injectors that are dribling after shut down causing a semi-flooding condition also there is a check valve in the fuel pump which is supposed to hold fuel in the system for the next start.
Jul 09, 2010 | 2000 Dodge Durango
Car leaks somethings when first starts--shut engine off and restart no leak Can smell some sort of gas fumes Had radiator checked-it's fine Recently had water pump, fuel pump replaced, tune up and some...
might be a small split or loose circle clip on a pipe, which would leak a little as pressure builds then lowers again. try letting your car run for 10 mins on a level dry piece of ground then look under it for any dripping or puddles or fluids.
Apr 22, 2010 | 1998 Oldsmobile Bravada
2000 2.0 vw shutt down after running 20 min
Replace the fuel pump relay, it's easy and cheap.
Jun 08, 2009 | 2000 Volkswagen Jetta TDI
Kitchen Ranges Logo
46 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
