Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
What does an "F 70" mean on the display panel?
  • 530 Answers
I believe you have a bad motor control board.
Posted on Aug 30, 2010
What does the trouble code 70 h95 mean
What does the trouble code 70 h95 mean - Fixya
www.fixya.com/support/t25932829-trouble_code_70_h95_mean
28 mins ago - what does the trouble code 70 h95 mean - Bowflex Treadmills question.
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - Please refer to the following table if your LifeSpan treadmill is displaying an error code. If after trying the suggested solutions your treadmill is .
Oct 30, 2015 | Bowflex Exercise & Fitness
When using our Sony Bravia to display pictures from an Asus Revo 70 nettop via HDMI, the picture often goes into reverse video - any idea what might be wrong, please ?
There is no obvious answer. Do you mean it goes 'negative' i.e blacks are white and vice versa?
It could be any number of reasons ranging from faulty graphics adapter in the pc, dodgy hdmi cable, incorrectly set up laptop or a video driver update required etc.
Any chance you could try it with a combination of a different tv set, a different hdmi cable to see if it narrows it down. Try changing the nettop output settings to different resolution. Is the resolution set correctly?
You are going to need to narrow it down. Also open the graphics control panel and check the settings.
Nov 17, 2014 | Televison & Video
My sony Bravia Model KDL 46ex523 shut down today , it has the little red light blinking 2 times , any idea what it means ?
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Make a visual check of all PCBs looking for burnt/overheated parts.This will help identify the problem circuit.
Read more: http://www.agoraquest.com/viewtopic.php?topic=31721&forum=70#ixzz31Blk7TRX
Apr 02, 2014 | Televison & Video
My toyo L-30 reads the temp then Lo for instance it currently reads 70 Lo. What does this mean?
Lo is displayed when the room temperature is below 14F or the heater thinks the room is below 14F, which would be caused by a problem with the room temperature sensor or the sensor is unplugged. 70 is what you have the heater set to maintain. Check the white wire on back of the heater.
Dec 09, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
My kenmore elite washer has a F 70 displayed? Wha...
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 21, 2010 | Kenmore Elite 45986 Front Load Washer
What does the code f-70 mean?
The central control board is not communicating with the interface.Unplug the unit and check wiring connections
Nov 01, 2009 | Kenmore Elite 45986 Front Load Washer
Infocus LP 70 projects a blurred display
Go to control panel and reset hardware configs that way.
Jun 29, 2009 | InFocus LP 70 Multimedia Projector
Error 70 / 60 /50
Those errors mean that there is an electrical or mechanical system fault. The pioneer website suggests to turn the car ingition off and on again, or press the power ON/OFF button on the display unit and try to play the CD again.
That seems like the obvious solution to me, which Im sure you have already done. You can try to contact Pioneer for more info.
Dec 05, 2008 | Pioneer CDX-FM687 6-Disc CD Changer
Image set up
Yes.
Baclight 80%
Contrast 70%
Brightness 50%
Color 50%-60%
Tint 50%
Sharpness -6 to -8
OPC off
Nov 30, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Refrigerator will not cool
Do you mean the display won't go below 70 or that the actual temps won't go below 70? First try to unplug the refer for 20-30 seconds then plug it back in. Hopefully that will reset the levels to factory settings (usually around 0 for freezer and 36 for refer).
Dec 18, 2006 | Kenmore 73503 Stainless Steel Bottom...
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
43 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
