Question about Dryers
My dryer comes on but doesnt spin anymore but the timer on it still counts down i have a maytag neptune its only 3 years old
Repairclinic.com has a lot of these problems answered on their website. a lot of old repair guys share their expertise via the site
Posted on Aug 30, 2010
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune MDE5500AYW will not stop unless it is unplugged
if you have it on time dry and it counts down but won't shut off you most likely have a bad computer board,part number 33003028 and it's around 180 dollars.on older machines it would be a problem with the timer not going to off but you have a computer board in your machine and it takes the place of the timer and other functions,just about everything runs through the computer board.
Jan 10, 2012 | Maytag Neptune MDE5500AY Electric Dryer
The neptune dryer timer doesnt work at all, it dryer fine just the timer button never moves and doesnt shut off.
Hi gordydugg...
Replace your timer it is defective and non repairable...
When you go to replace with your new timer, I would recommend that you remove and replace one wire at a time.
Please take time to rate me thumbs up
Sep 19, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer starts/ stops
recycle power. if problem persists, timer problem
Mar 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer fills with water and thats it
Possible a bad motor control board. Depending on the age of the washer, you may need to replace the motor control board and the motor as a kit. Also be sure to test that the motor control board is getting power, I've seen cases of the motor/ motor control failing and taking out the main control also. The tech sheet is in the console and should walk you through the steps.
Jul 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Wont work, flashes LR
rapoyner The "LR" error code means "locked rotor". It appears on the display after the machine has repeatedly tried to turn the motor. The cause of the problem could be the motor itself, the motor control board, the main control board or the wiring. If your washer is less then five years old most likely the parts are still under Maytag warranty. It has very sophisticated design and I wood recommend to call the Maytag authorized repair man even if the warranty is already expired. Gendos
Jul 06, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Dryers Logo
44 people viewed this question
Top Dryers Experts
