Question about Kenmore Ovens
Where should the igniter for the oven be placed? Could show me diagram?
  • 530 Answers
What is your model number?
Posted on Aug 30, 2010
Chef premier 091S16FE1 gas cooker. Igniter will not work in grill or oven. Switch tests ok. Need wiring diagram. Would like to know if there is a fuse in the system.
I dont have a diagram but most Chefs have a wiring diagram stuck behind the lower kickpanel or underneath the warming drawer ( if fitted) The Premier was a fairly basic unti when it came out. A lot of these had battery ignition. Look behind the kickpanel or under the warming drawer for a battery box. ( About the size of a matchbox) and has a 9volt radio battery.
I have not seen fuses in these ovens for over 10 years , so I would suggest that yours doesnt have one.
Jul 26, 2011 | Ovens
My maytag oven CRG 300 gas oven will nit light when wanting to use the oven. the top works well. i have pilotless ignition. wht will it not light. I hear the ignition and hear gas.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jan 29, 2011 | Ovens
The to oven bake doesn't work but the top Broil works. What ever brings on the igniter for the bake isn't working because I get ne power to the egniter. I don't have a wiring diagram to check any futher.
I replaced my Amana Gas wall oven Model AOGD2750E Lower Oven bake Igniter and temp sensor but still not working. I'm Thinking maybe the relay module is at fauly, Any suggestions, I need help!. Thanks
Jan 27, 2011 | Amana AOGD2750 Gas Double Oven
Why oven won't get hot. .
Dec 02, 2010 | Magic Chef 9112 Gas Double Oven
I have a kenmore gas oven/range model 362.752.6190. The oven will not ignite but the range burners work great. I assume that means its the ignition system on the oven. Do you know where I can get a new...
Dec 01, 2010 | Kenmore Ovens
Glow stick comes on but oven will not light
Nov 22, 2010 | Amana AOGD2750 Gas Double Oven
The oven will not light. I took the upper and lower panels out and cleaned what I could. The oven lit until I put everything back together. The oven does not ignite. The broiler operates.
Oct 14, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Amana oven will not ignite
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jul 22, 2010 | Amana Ovens
Control panel on my Maytag MEW6530DDS not working / how do I open the panel and replace it?
there are screws that hold the frame that holds the panel in place. they are usually 3 at the top of the oven. after removing them you take that piece off and you then take out the other screws that show themselves. it is kind of like a puzzle. one suggestion is to make a crude.drawing on cardboard of the oven and stick the screws thru the cardboard and then you will know where they go when you put it back together. learned that trick the hard way. and make a drawing of the back of the oven control board and make a diagram of it that shows where each wire goes so you will not get them mixed up when you put the new one in. we had to order the wiring harness that goes from the control board to the oven thermostat. it was back ordered for 3 months. if i had not made that diagram i would have been lost when i went to put it back together. went online and found an oven control board for $120 installed it and the oven has worked ever since. this oven has a bad setup that channels the heat right by the oven board and it ruins the control board.
Jun 21, 2010 | Maytag MEW6530D Electric Single Oven
Oven not getting to proper temperature
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Dec 06, 2008 | KitchenAid Architect Series KEBC208KSS...
Ovens Logo
35 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
