My Carrier FB4ANF036 unit is located in the garage. Water is dripping on the garage floor and creating an unhelathy situation. Could it be the drain line is clogged? How do I access the unit to try and clear it? I know there was a product called "Sludge Buster", which was a small white tablet that would clear the drain line. What can I do?
  • 32 Answers
The drain is clogged try cleaning it out with a shop vac from out side or if it is low on freon it could be frezzing up is it still cooling!!
Posted on Aug 30, 2010
My Carrier Infinity system Model FE4A is leaking water from the bottom of the unit on to the basement floor. How do I stop the leak?
have your HVAC technician check the pressures in your unit...sounds like you may have low pressure. You should NOT be having any ice build up to melt off.
Sep 13, 2014 | Carrier Infinity Series Variable Speed...
I HAVE A MAYTAG AUTOMATIC ELECTRONIC DEFROST CONTROL REFRGATOR MODEL MSD2272VEB00. EVERY FEW DAYS WATER LEAKED FROM UNDER THE REFRIGERATOR ONTO THE FLOOR FROM WHAT APPEARS TO BE AT THE FRONT RIGHT SIDE OF...
Inside of the unit is a drain hole that will drain out water to the drip pan. The drip pan is located under the unit and it uses the heat of the motor to evaporate the moisture that collects in it. The drain hole is plugged. Go on youtube and you can watch a video on how to fix it. Very easy.
Semper Fi,
Z
Apr 27, 2017 | Refrigerators
Pool of clear water on floor of garage overnite
ok , can I assume you run green, yellow, orange ,pink antifreeze
in the radiator, not pure water, and check AF every fall for 50% consenstrations? yes.
then that water is normal Airconditioning condensate water that all cars drop to the ground. pure water it is.
THE A/C runs when you ask for COLD or Defrost.(front)
and works just like a cold beer glass in a humid tavern. it drips.
Jan 26, 2014 | 1994 Toyota Corolla
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
Jan 16, 2011 | Carrier 52CQ315 Air Conditioner
Have model number FV4BNB006 air handler and condensate is not running down the coils and into the drip pan. It is falling directly on to the filter and into the air box creating a large water issue.
Be sure the unit is tilted slightly to the rear and that the back drain
is clear. Also the floor of the unit should be clear of sludge,etc.
so the water can drain from front to rear and out the drain.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 31, 2010 | Carrier Heating & Cooling
Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
May 21, 2010 | Carrier 38CKC036 Air Conditioner
Water on the floor under the freezer side of unit
It happens to all those old refrigerators. There is a shield separating the drip container and freezer through a small hole. Check if it is blocked. This won't do much of the work and may not be stopped even if you do something. If you can, have a new refrigerator.
Apr 21, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Water leaking from under refrigerator
The drip pan is located from behind the refrigerator. You have to take the cardboard off and unplug the unit. You will see the drip pan with the fan unit on top of it.
Apr 29, 2009 | Refrigerators
Heating & Cooling Logo
379 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
