Question about Frigidaire Affinity ATF8000FE
Fails to spin out after wash cycle - Frigidaire Affinity ATF8000FE
  • Frigidaire Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 30, 2010
WhIzAtIt
  • 136 Answers
SOURCE: Ariston A1435
Usually there are two windings for washers, One goes forward and one reverse, either one is bad OR: There is also a transmission in washers that when washing; they agitate the load when spinning; they, well spin! (ha) If it wont wash then there is either an internal component in the tranny bad or a solonoid that has gone out. Take the cover off and check to see if the belt is ok as well. Let us know :-)
Posted on Sep 15, 2007
IFIXALL
  • 868 Answers
SOURCE: Spin Cycle Fails on Washer
This solution is 100% correct, change the : wax motor &control board.I'll be happy to guide you through this if you need me to.
Posted on May 26, 2008
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
  • 57 Answers
SOURCE: washing machine fails to drain and spin at the end
its the brushes on the motor or the pump is blocked or defective
Posted on Jun 24, 2009
SOURCE: My Frigidaire Model fails to spin after wash
my washer had same problems, turned out to be door lock switch. around $75.00. Washer 2 years old. Questioning quality also.
Posted on Feb 14, 2010
My kenmore top load washing machine washes but wont drain or spin
The spinning cycle may be detecting that your tub is unbalanced and will not proceed. Check that it starts and fails when the tub is spinning slowly. Otherwise you may have a faulty drain relay or debris is plugging the drain out hose.
Feb 01, 2015 | Kenmore Washing Machines
Frigidaire washing machine (FTW3011KW0) runs through all cycles, agitates, pumps out water, but doesn't spin, nor does the motor attempt to spin during the spin cycle
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad.
murf427
Jul 31, 2012 | Frigidaire Washing Machines
Hi, I've just done a wash on my Hotpoint WMA35 but it will not do the spin cycle. I hear the usual whirring sound as if the spin is about to start, but it doesn't. I've rearranged the load but still...
Any flashing lights or extra solid lights on the control board? By "spin cycle", do you mean the final spin cycle and drainage of water through waste pipe (basically, I want to know if the washer spins then fails, or fails to begin any rotation of the drum whatsoever). I'm having problems with my WMA35 myself, so it'd be interesting to see if this a common fault.
Feb 07, 2011 | Hotpoint WMA35 Front Load Washer
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
No Spin Cycle
Your machine won't go into spin cycle most probably because it awaits for pump to start extracting water out of the basket. If the "Door Locked" light is on th an it means that either filter, pump or drain hose are clogged (unless pump burned). Turn off machine, unplug the machine, clean the filter, check for foreign objects inside filter and pump housing and finally check/unclog the drain hose.
Apr 23, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Zanussi 1245w fails to spin
suspect it may not be rotating on wash either. check the moor brushes
Mar 30, 2007 | Zanussi F1245W Front Load Washer
Frigidaire Affinity ATF8000FE Logo
128 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
