Washing machine door bracket
Door bracket
  • ramsrus May 12, 2008
    i took the part into a local hardware shop that supplies electrical and other parts for washers cookers etc and they supplied it on the spot and i fitted it myself
Replaced it with new one from hardware
Posted on May 09, 2008
Hi, i have ONHF 6117 Hoover washing machine which dropped out of my van while moving house the problem is there no motor action, i had someone look at it he changed the pcb module board, motor and pre
All washing machines have a switch that is activated when the lid or door is closed. This tells the machine its safe to run the motor. If this thing dropped out of a van, it's possible the housing twisted and the little metal bracket on the door is not making contact with the safety switch or the switch may now be broken.
Nov 25, 2014 | Hoover Washing Machines
Water flows out door while in use
Check the door gasket/seal for damage. Check to see if the door's mounting brackets are loose by lightly moving the door up/down. Also check the level of the machine to ensure that the frame is not twisted.
Apr 22, 2014 | Maytag Neptune Washer
Door does not close ease
It is the door latch! Spray some WD40 where the U shaped bracket goes into the machine. There will be a hump on the door lach assembly is do not go over board wirh whe lube a little goes a long way.
Jan 24, 2013 | Maytag Neptune Washing Machines
Wd62p replace hinges
First of all remove the door from the machine by unscrewing the screws on the hinge than remove clip at the top of door seal, when it unclips remove metal band, pull front of door seal off of front panel, Pick up metal bracket. Now with the hinge attached to door hold in place and place bracket behind the two holes fit screws and then fit the seal and clip.
Regards
May 05, 2012 | Hotpoint Ultima WD72 Front Load...
Can the door be switched to the other side on a kenmore HE2 pkus washing machine?
look on the other see if u c brackets or hinge places for the door to go to the other side iif not no
Nov 10, 2011 | Washing Machines
Hi, i bought a brand new indesit washing machine pwc8108w. please let me know how to open the door to get my operating manual. because door is locked, i cant open the door.
Hello
There should be a pause button on the console,hold it in for 3 seconds.First you need to plug the machine in.
If this does not work,simply unplug the washer and the door will unlock.
Also check for any shipping brackets under the machine or on the door that may need to come off.
Mar 29, 2011 | Washing Machines
I have a LS612 dishwasher and cannot open the door
If you remove the top lid, you will see a bracket in the middle of the door in the front. There will be a bracket which connects to the latch held on to the frame by a small nut. Undo that nut with a long nosed pliers and slide the door open. Remove the bracket then replace it back again.
Nov 13, 2009 | Washing Machines
I have a hotpoint wm63, the door hinge broke, which i have replaced, but the nuts to fix the door back on have fallen inside the machine, i guess i eed to get inside to refix the door, but how do i do...
It is not nuts but an internal bracket. You can access it from underneath by stretching your arm inside once you have found the bracket. REMEMBER TO POWER OFF BEFORE PUTTING YOUR ARM IN!
Aug 06, 2008 | Washing Machines
Door lock flashes
Your switch bracket or switch is either broken or you have no either to or from it. Check your switch first.
Dec 18, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
