Question about Sony PlayStation 2 (PS2) Console
Vibration malfuction I have bought already 2 playstation '2' consoles and neither of them had the vibration function in working order. I always check the game settings to make sure that it's on but it never vibrates, and both of the controllers work properly. One of them is a Sony brand the other is aftermarket but neither obe of them vibrate! Please help! Tks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The controller will still function as normal,
But inside there is a BENT / CROOKED / weighted, spinning mechanism in one of the protruding grips... that often straightens or gets stuck.
The only way to fix it is to take it apart - EASY!
Putting it back together is - NOT!
firstly, spray the pins with a contact cleaner.
Posted on May 09, 2008
I have a dualshock 2 analog controller for the PlayStation 2, and after a couple of years, the vibration function quit working. What can I do to get it back working again?
Take it apart and check that the little motors are OK if faulty replace them if not the fu? part starts now
Check the wiring back from the motors and the printed circuit board for damage or a poped component
Or buy a replacement
Oct 14, 2016 | Video Game Consoles & Games
Playstation game won't read controller
chances are you controller is broken if not it your controller port
Oct 05, 2009 | Sony PlayStation 2 Slimline Console
I have a fat ps2 with a rumble controler problem
just keep ure ps2 safely and always shining . so always clean ur ps2 and make the best use of controllers carefully
Sep 19, 2009 | Sony PlayStation 2 (PS2) Console
Vibration function
Try a different game, either its the controller, the game, or worse would be your ps2 is busted.
Jun 11, 2008 | Sony PlayStation 2 (PS2) Console
Removing old parental lock out codes on used ps2
here is the answer to your prayers http://www.techlore.com/article/10505/
Jan 11, 2008 | Sony PlayStation 2 (PS2) Console
Playstation 2
if you bought your PS2 where you live then you have a region code problem ..Please make sure the Region Code of the software matches that of the North American PlayStation 2 system. Only discs (games and movies) coded with regions "1" or "All" will work on a North American PlayStation 2 computer entertainment system. Consumers residing in the United States or Canada must use a North American PlayStation 2 console in order to view "Region 1" content.
this is same for yours too..
Dec 05, 2007 | Sony PlayStation® 2 Console
Ps2 dualshock analog controller not vibrating
Usually, all dualshock controllers malfunction after a year or so. Do not be surprised.
Sep 10, 2007 | Sony PlayStation 2 (PS2) Console
Playstation two controller
Its possible the connector on the PS2 has come loose on the inside of the unit. The other possibilty is that the connector on the end of the cable of your controller is dirty or loose. If its just the controller connector, try taking a cue tip and some rubbing alcohol and cleaning the connector on both the controller end and the ps2 end, just be sure that you don't turn on the PS2 until the connectors are completely dry. If you use rubbing alcohol it should take less than a couple mins for the alcohol to evaporate
Aug 26, 2007 | Sony PlayStation 2 (PS2) Console
Playstation 2 Slim
In this case the optical unit (laser) is malfunctioning. Please check the type of optical and provide a replacement in order to repair the unit. If you need more info please advice.
Apr 14, 2007 | Sony PlayStation 2 (PS2) Console
Ps2
The special fuse inside the PlayStation unit is broken. If you need more info please advice.
Mar 31, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
66 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
