Question about Ovens
Cleaned now wont turn on? power clock flashing
  • 530 Answers
Sounds like you have a built in kitcheaid oven? usually blows the safety fuse in the back of the oven. it's proper name is thermal cutoff. need a model number for the part you need
Posted on Aug 30, 2010
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Jul 06, 2011 | New World Ovens
Clock keeps flashing i keep setting clock but after 5 minutes or so starts flashing again putting tape over ready time button to hold it down then reset clock seems to work till the tape comes loose Stove...
It looks like the clock is on its way out. I would try two things. First, turn the power off at the main switch, leave it off for a few mins and then turn it back on and see if it makes a difference. You may need to do this a couple of times. Secondly, with the power switched off, repeatedly press all the clock buttons one at a time a number of times - there may be a contact that needs cleaning by operation and then see what happens. if you do need a new clock/timer then ask espares for a quote.
Nov 14, 2010 | Stoves 720EF Electric Double Oven
Power went off now oven wont work. The timer keeps flashing
If you look at the timer control you will see a button that is used to set the clock. most likely the oven will not operate until the time is set. Press the clock button, set the time and either press start or the clock button again.
Aug 29, 2010 | Ovens
My oven wont work afte a power cut its flashing oo:00 auto and I dont have a manual
you have 2 buttons one pops out for adjustment the other is only a push button push the left hand one repeatedly till a red clock symbol shows at top of clock then turn right hand knob to set time wait a few seconds and clock will set itself.
Nov 16, 2009 | Neff B1421 Electric Single Oven
Lock light flashing after cleaning. Will not
OK, what has happen here is, the actual temp sensor has failed during the cleaning process, this has cause a temp that reached a dramatic high range(above 915F-930F). At these temps, there will be major damage that will weld the contacts on the door lock switch mechanism and control board.
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches for faults as well(welded contacts and burned wiring harness)
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Sep 23, 2009 | GE Ovens
The oven won't come on, the digital timer just flashes continuous
Hi
have you tried setting the clock as the oven wont work if the clock is not set. hope this helps
regards dan
Mar 19, 2009 | De Dietrich UMP404 Powerclean Stainless...
Zanussi oven wont work. clock flashing 'auto'
you need to set clock before oven will work. do you still have instruction book as it will tell you there how to do it
Jun 18, 2008 | Zanussi ZBQ665 Electric Single Oven
The clock started flashing as if the power went out. Then when we tried to
The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle)
May 22, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Dec 14, 2006 | Smeg F170 Pyrolytic Stainless Steel...
Ovens Logo
41 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
