Question about Dishwashers
Have a 8 year old GE dishwasher. It fills and then pumpsout, then fills agian and pumps but on the last rinse it keeps filling. If you don't shut it off it will over flow out of the front. Any Ideas?
  • davidgalb721 Aug 31, 2010
    Thank You! It was the water inlet valve.
  • 12,061 Answers
I imagine your overflow float switch may be jammed, or the flood control sensor isn't working properly. It may even be the controller, there are just many things that can case the same or similar symptoms, but have widely differing causes, one must troubleshoot as per the help websites, or the service manual.
Please find below a Dishwasher troubleshooting how to..
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
What you need to do, is if you wish to DIY, is obtain a service manual, for your exact make and model. look at the below website to get your service manual.
http://appliancejunk.com/forums/
If you do not wish to DIY, then please call a GE service center and ask for a service call, then ask for a "Quote" for any repair.
Posted on Aug 30, 2010
GE Dishwasher leaking
HI,
If you're just looking at the machine the problem is not going to be fixed..
and now the question: in witch cycle is leaking?
fill, wash or rinse?
can be...for fill...one hose from filling is broken.
for wash...mechanical seal from wash motor, the plastic manifold,one gasket.
rinse..manifold or hose for the rinse...rinse pump..
for drain..solenoid for drain, the hose for drain..
Anyway you must open the machine first of all and see.
Good luck
Jun 30, 2013 | Dishwashers
Dishes seem to have a powery residue on them after they're clean
Check inlet water quality for hardness. If salt chamber is provided, fill the chamber with salt meant for washing machine.
Use the recommended wash soap.
Check rinse aid and fill if required.
Jul 20, 2010 | GE 24 in. GLD5560LSS Stainless Steel...
Recently glasses started to finish foggy and
MOST OF THE TIME "FOGGY GLASS" IS A RESULT OF SOAP BUILD UO IN THE DISHWASHER. IF YOU HAVE A WATER SOFTENER AND FILL THE SOAP CUP ALL THE WAY THEN THIS IS THE CASE. FILL A COFFEE CUP WITH WHITE VINEGAR AND PLACE IT ON THE UPPER RACK, RUN AN EMPTY LOAD ON HEAVY DUTY WASH, THIS WILL STOP THE PROBLEM, YOU MIGHT NEED TO REPEAT IT 2-3 TIMES BUT IT WILL WORK, AFTER THAT JUST USE AS LITTLE SOAP AS YOU CAN, IN MY GE I USE POWDERED CASCADE BUT ONLY FILL THE SOAP CUO TO THE BOTTOM LINE, WORKS GREAT. GOOD LUCK
Jun 10, 2010 | GE Nautilus 24" Built-in Dishwasher
NOT DRAINING AFTER RINSE CYCLE
Dishwasher is not filling in first cycle. only in rinse cyle then it won't drain it
Jul 31, 2009 | GE Nautilus 24" Built-in Dishwasher
I have a GE GSD2230Z00WW dishwasher water will not fill on start no power on the fill valve either. Water will come on quick wash cycle and rinse.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
***If everything checks out ok with the water inlet valve, replace the timer or control board.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Rinsing agent dispenser empties too quickly
has the seal ring fallen away? is the flap shutting properly/ try setting it to a lower numbered setting.
Mar 14, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
GE Triton Dishwasher will not drain they water after it's cycle...thoughts?
Peace,
Cut off the power at the breaker for 5 minutes and then turn it on and see if the system resets!
The machine was in your home 3 years , and used for more than that by someone else! I can tell you by the model that its at least 10 years old!
appliances more than 9 years old cost you money to run and fix! Throw it out and do not put good money into bad!
The new ones no matter how inexpensive will wash better and cost you a hell of a lot less to operate. They are so much more energy efficient today that they pay for them selves in a couple of years! With a new machine watch your water and power bill go down!!!
Other wise you need hands on service!
if you got the money do it new!
Bless You!
Sep 02, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwashers Logo
62 people viewed this question
Top Dishwashers Experts
Owen Barnes
