Question about Crunch Noxx PZN2200 Car Audio Amplifier
I have a 700watt crunch amp and when i turn on the power the power comes on then goes out what will i need to do to fix the problem
Crunch 2000.4 car amp, need help tuneing
re-check the speaker connections are correct and use a matching ohm test speaker on the other connections for a sound check. Sounds like hi frequency output into the sub amp. Sub-woofers are a mono signal!!
Jul 17, 2017 | Crunch Car Audio & Video
I unpluged my amp from my car and i forgot where all the wires went i need help to hook back up right
There should be a group of screw terminals. They should say pos or (+), remote, and ground, GND, or (-). This is the power terminal. The power from the battery goes to the (+), the remote turn one (thin wire) goes to the one labeled remote (usually inbetween the ground and power wires), and the ground to the (-). RCA jacks should be labeled input and output. Plug the appropriate colors in the input ones. The speaker terminals are labeled left and right + and -. If it is a 4 channel amp, it will also have front and rear. Depending how you wired your speakers is how they will go to the amp. Follow the speaker wires to the appropriate prongs positive or negative. Hope this helps.
Aug 26, 2011 | Crunch Car Audio & Video
I have a Crunch Powerzone Pzi2250 1000 Watt Amplifier. and the red light blinks. What does that mean
My crunch powerzone pzi2250 1000 watt 2ch amp is stuck in protect mode. How do I fix this at home
Jan 16, 2011 | Crunch Powerzone P4175 Car Audio Amplifier
I have a crunch pzi 1000 that blows the main fuse when ever the main power wire is connected and power comes out through the inputs??
hello ! there is a short circuit   on power section  need to  be checked and fixed  some Transistor or IC, diode  burnt  .
The fuse gets blown coz power is reversed back  at primary level ,power supply.
good luck
Oct 03, 2009 | Crunch Powerzone P2125 Car Audio Amplifier
My Crunch Amp In My Blazer Has Stopped Working! Please Help!
NO if your amp is good any battery will turn it on. changing batterys does not require a reprogram?. id say amp is damaged from being wet. test to see if power is going in and out if nothing out bad amp..
Jun 01, 2009 | Crunch GP1100.2 GroundPounder 1100W 1/2...
Changed speakers and now red protect light stays on? why?
the sub might have a short or is blown or the ohms are different
Mar 30, 2009 | Crunch PZi1000.1 Car Audio Amplifier
I hookled up a crunch amp to my vehicle and the protect light comes on......
You Conected the power cables up wrong and the amp is protacting its self from being fried.Make sure positive and negative and remote turn on is correct
Nov 29, 2008 | Car Audio & Video
Crunch GP 3000 D Pro
It's very likely that the output transistors have failed in the amp. They will need to be replaced.
Jun 14, 2008 | Crunch Drive V-600 Car Audio Amplifier
Amlifier not working
connect your remote turn on and your problem will be solved
Sep 23, 2006 | Crunch BlackMaxx BLX2000D Car Audio...
Crunch Noxx PZN2200 Car Audio Amplifier Logo
53 people viewed this question
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Matthew Spark
Matthew Spark
Tygh Duval
Tygh Duval
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
