Question about Meade ETX-60 AT Telescope
Adjustment lever part is for the ETX 60AT tripod leg. Two of three are okay but the third is broken. Never been out of the box.
  • 3,186 Answers
Contact Meade directly for any replacement parts. You might also find something at a well stocked hardware store that will also work.
http://www.meade.com/support/index.html
Posted on Aug 30, 2010
How to repair take up lever
How to fix your tripod if its broken - YouTube
? 12:23
www.youtube.com/watch?v=zQfMik-2sTE
Dec 15, 2013 - Uploaded by Chris Rubei
Why was i fix my broken tripod. ... Repairing the aluminumlever tensioned tripod legs Velbon HG4.wmv - Duration: 2:41. by wtam69 1,535 ...
Aug 28, 2015 | Photography
I need instruction manual for manfrotto 058b tripod
There is a red slider under the main casting that will release the legs all together.
Apr 13, 2013 | Manfrotto 058b Triatt Camera Tripod Black
Allegro tripod legs won't lock
Maybe it could be the clasps not the locks that are broken if you need it functioning right away wedge something in between the clasps, and locks, or the clasps could be over expanded shortten that, and you'd be set.
Feb 22, 2013 | Photography
60at motor fault
Could be several things:
You did Train the drives and CALIBRATED motors using the same power source you will use outside?
Do not run off of the internal batteries UNLESS they are brand new. Once the batteries drop below about 70% the hand controller goes a little crazy. That's why most people use an external power pack.
1. Replace the batteries, and do a Calibrate motors.
Did this fix it?
Mar 21, 2010 | Meade ETX-60 AT Telescope
Leg slips will not lock
Although I'm not familiar with your particular make and model it sounds like a common problem which affects many other tripods. If the legs clamp with a lever action then if you closely examine each clamp as you activate the lever I expect that you'll find a small crack opens up in the clamp assembly.
It's a faulty design as the clamps simply aren't strong enough for the load and eventually crack due to fatigue. Some manufacturers supply replacement leg clamps but they also fail and fitting them usually costs more than the tripod is worth.
Next time, consider buying a tripod which has rotating collars to lock the legs with. They're not as quick to operate as lever action (a.k.a. "quick release") clamps, but they don't take much longer and last far longer. Rotating collar clamps are only suitable for tubular legs, and to be as rigid as extruded profile legs there's usually an increased weight penalty unless you spend far more on carbon fibre versions.
Personally, I tend to buy cheap but perfectly good non brand name lightweight tripods which I can get for £10 including a carry bag and handle and expect to have to replace them when broken: usually about once a year. It's a lot cheaper than spending over £300 on a good one and means I can afford to have a spare one in the car.
ALDI (in the UK and Europe) sell a £10 tripod which comes with a handle, carry bag, pan/tilt head,quick release leg clamps, geared centre column plus two quick release mounting plates and has a bag hook at the bottom of the centre column; it even has a no quibble three year guarantee. It's not a smooth or as well built as many, but can't be beaten at the price.
Aug 06, 2009 | Vinten 3770-3 Tripod
Broken parts/EQ-3700
Most of these parts can be found at a well stocked hardware store-- and you can make a micro adjustment rod.
Apr 06, 2009 | Optics
Leg clamp tightening adjustment on a 055 tripod.Under weight the leg telescopes in on itself. Clamp doesnot grip tightly enough on the middle diameter leg tube.
There should be a nut on the other side of the housing of the tightening lever that you can tighten. Turn the lever to unlock the leg then start with 1/8 th turns of the nut to tighten, then turn the lever to lock the leg. Do this until you get the desired locking.
Mar 17, 2009 | Bogen Communication Photography
Vivitar tripod V900 has a broken friction level
Vivitar has been out of the tripod business for a few years now. They may no longer have the parts. You may be able to find another V900 and scavage the parts. Make sure the model numbers match exactly. The V900SE is a different year and does not share the same parts as the V900.
Jan 01, 2009 | Photography
Leg lock broken
Assuming you still have the female part with the treads in tact, you can do what I did. I used a hose clamp, the kind used on radiators, but larger. First, take off the lock down knob, then put the hose clamp over the broken plastic housing and mark where the knob would screw through. Then remove the hose clamp, placing it on a sturdy surface and use a 5/16 drill bit to make a hole where the lock down know will pass through. Place the hose clamp over the plastic housing, insert the knob, tighten the hose clamp (but not so much that it restricts the tripod leg from moving) and you are done! I can send you pictures of the process and the final result. It saved me from buying a new tripod! I can be e-mailed at boingsplatplop@yahoo.com if you have questions.
-Spencer
Nov 07, 2008 | Photography
Meade ETX-60 AT Telescope Logo
106 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
