Question about Samsung 24.6 Cu. Ft. 4-Door Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
We had this ref for almost a year now and it has not made ice in 2 days..Help please!!!
  • Samsung Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Aug 30, 2010
I have a french door stainless LG refridgerator with the freezer on the bottom. I have ice building up in the bottom of the freezer. When I pull out the drawer there is a layer of ice on the bottom. ...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 19, 2011 | LG LFC23760ST Side by Side Bottom Freezer...
Ice maker has made only 4 ice cubes in 2 days..From day 1 ice always stuck together-never loose. always slow, but this is really slow. we purchased this model TBH21JA IN 1993 STILL LOOKS very nice--ice...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
If you still have trouble GO HERE:
I'm
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 06, 2011 | General Electric Refrigerators
Hello Heatman101....I have a 2-3 year old Whirlpool frige,bottom freezer.The humidity in the past month around Ottawa Canada has been extreme.It seems on these days water is leaking on my hardwood oak...
Leo Ponder
imufo2
Aug 24, 2011 | Whirlpool Refrigerators
When I turn off my ice maker for a while, like a day or two, then turn it back on, the filler tube freezes and prevents water from entering the ice tray. It takes an ice pick to free it up. Can this be...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Leo Ponder
imufo2
Aug 20, 2011 | Frigidaire FSC23F7D Side by Side...
ET1MHKXMB08 refridge is not very cold but the freezer freezes on the bottom self and the top part is cold. not a true frozen situation,odd only 2 years old and fan works big dome on bottom back of unit is...
I'm Leo
Leo Ponder
imufo2
Jul 27, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Our Whirlpool Bottom Freezer Refrigerator (model EB9FVHXVQ)has been acting up for over a month. The freezer is VERY frozen and the refrigerator section is warm (room temp). I tried unplugging the fridge...
I'm Leo
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Also check evaporator fan in freezer
If this was helpful please rate me
Leo Ponder
imufo2
Thank you for using fixya
Leo Ponder
Please VOTE FOR ME IF THIS WAS HELPFUL.
Please click for article
Jul 26, 2011 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
"Hi, I have a questions
It seems you will need a service technician again. Be sure you got a warranty if you agreed to service your refrigerator. If you use the refrigerator correctly it will never go bad for less than a year and call for service repair. But if you definitely used it correctly, chances are the refrigerator you brought have a factory defect.
I hope my advice help you.
Jun 15, 2011 | Refrigerators
GE GSH25KGMBWW REFRIGERATOR WON'T GET COLD AFTER REPLACING SOLENOID
The ref is iced up because of the ice door being left open, you will have to manually defrost the ref by leaving it open for 7-8 hours,put you food somewhere else.
38 years exp burke
Sep 22, 2008 | GE GSS25JEM Side by Side Refrigerator
GE Ref #ESS25LSRCE SS
are you sure it is not a GSS or a PSS model i have the manual on that post your email and i will send it to you
Mar 10, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Samsung 24.6 Cu. Ft. 4-Door Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
107 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
