Question about Hitachi 43FDX01B TV
The horizontal is out of adjustment
The top and bottom approximately 1 inch of the picture is off screen. TYou can't see a scroll on top or bottom.
  • Dandre May 10, 2008
    Excuse my ignorance, but I have no idea what the 'solution' means.
    My old tv would take care of this problem by adjusting the 'horizontal hold' to bring the top and bottom of the picture into alignment with the frame.
    I was hoping for that type of solution.
  • 85 Answers
Open ur tv and find the 100uf/35v and change it.
Posted on May 08, 2008
UN46EH5300 adjust screen size to get whole picture and closed captions
Sounds like you have it on zoom setting. Go to the picture menu and scroll through the options. Start with 16:9 and try others if this doesn't work. If you've already tried this, you may have to go into screen setting and manually draw the picture in horizontally and vertically - but make sure you've got it on 16:9 and paused on a typical picture before you mess around with these settings.
Aug 22, 2014 | Samsung Un46eh5300 46 Inch 60hz Led Hdtv
E472VL picture on HD cable channels does not fit screen correctly-how can we fix it?
Consult the manual---the answer lies in the size controls being grayed out so you cannot adjust or try to adjust the vertical size!
Mar 28, 2012 | Televison & Video
Need help adjusting my screen. It is off by approximately 1/2 inch.
scroll to the user options menu, then system settings, then tap the next tab at bottom right, then go to the diagnostics tab, then touchscreen test and follow the instructions on the screen.
if you need further help, just post back to me
Bill
Jun 02, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
HORIZONTAL LINE THROUGH PICTURE
Defective LCD panel. I hope it is under warranty, otherwise you'll have to live with it or buy a new set, as the LCD panel costs almost as much as the TV itself.
May 20, 2009 | Sharp Televison & Video
Control of vertical TV image projected on the screen
You can try looking for 2 things
1. A button on your remote that says either: ARC, Ratio, 16:9, 4:3.... Some remotes have a picture of a square with arrows pointing out towards each corner..... I'm unfamiliar with this set, but it sounds like a widescreen, so give it a go
Apr 22, 2009 | Televison & Video
Scrolling screen
There's a horizontal adjustment that needs to be made in the TV. If you feel mechanically inclined, you can take the back cover of the TV off (Be very careful with this. If this is a CRT (picture tube) then there is a capacitor at the top that has ALOT of stored energy.) You will see a couple of potentiometers (Looks like a little black wheel with a slot for a screwdriver). One of these will be the horizontal adjustment. Very slowly try to turn this until it adjusts.
If you give me the model number and brand of the TV I can try to find you a manual that will help you determine which one to adjust.
Apr 07, 2009 | Philips Televison & Video
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
19" hansol 920p monitor
To my knowledge, it is not the zoom that has to be adjusted but rather the horizontal width, zoom would expand all (to, bottom & both sides) whereas your only concern are the two sides.
Should the horizontal width not fully expand, then there is an internal problem with the horizontal deflection circuitry which could either be the yoke, a capacitor or shunt diodes. In certain instances, a below normal voltage at the mains or the internal power supply could also cause this.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 21, 2008 | Hansol Multitech 920p 19" CRT Monitor
Hitachi 43FDX01B TV Logo
44 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
