Question about Navigon 2100 Portable GPS Receiver
Fix mn6/exe navigon 2100 - Navigon 2100 Portable GPS Receiver
3 Suggested Answers
SOURCE: The MN6.exe fatal Application error is displayed
push the reset button on the side of the system (a paperclip works well for this). Also, remove the card and put in again. If this doesn't work go to Navigons website and make sure you've downloaded all the software updates. Make sure your unit is fully charged as well. Don't waste your time emailing Navigon's CS online help....I attempted to contact them on 3 separate occassions and never got a response. Good luck. Hope one of my work-arounds helps you.
Posted on Jan 26, 2010
SOURCE: navigon 2100 mn6.exe fatal error message....going
I got mine back up and working by doing the following:
1st Icopied the files on the SD Card to my pc (for backup)
2nd I deleted all the files on the SD Card
3rd I went to the following link https://www.navigon.com/site/us/en/my_navigon/unauthorized/products_us
and download the update for Navigon 2100 and installed it.
Tested it and it no longer gives me the fatal error.
Posted on Aug 15, 2010
Fs201
I would suggest going here and reading about your unit.
http://reviews.cnet.com/car-gps-navigation/navigon-2100/4505-3430_7-32744602.html#reviewPage1
Go through the 2 pages.
Good luck
Apr 10, 2012 | Navigon 2100 Portable GPS Receiver
Application MN6.exe has performed and illegal operation and will be shut down program: mn6.exe eception :0xc0000005 adress:00000000
this is a very common problem with this unit.
What version do you have on your Mio Moov?
I have that error when I run the 2100 version on my Mio Moov. I can run the 7200 software without a problem...
Give it a trial.
Regards.
Jun 13, 2011 | Navigon 2120 GPS Receiver
My Navigon 7100 no longer speaks the street names after I downloaded the latest software updates.
I had the same problem and this fixed it: Connect the navigon to your computer and go into the files directory and create 3 new empty folders, as follows: (You may want to back up your navigon 1st) After i created these empty folders, I was able to go into settings and turn Stree names on
Create these empty folders within MN6\sound folder.
Celine_67_tts
Isabela_22_tts
Sarah_21_tts
May 13, 2010 | Navigon 7100 GPS Navigator GPS Receiver
Navigon 2100 car charger unscrewed. Found a few
[PDF] NAVIGON 2100/2120 User's Guide Your NAVIGON 2100/2120 comes with the following accessories. .... With the NAVIGON 2100/2120, you can also use an external GPS antenna (not pro- ...
support.navigonusa THEIRS A SITE FOR YOU YOUR FUSE IS A 6V 1 A RADIO SHACK SHOULD HAVE ONE OR PACK OF 5 6 BUCK OR SO
May 08, 2010 | Navigon 2100 Portable GPS Receiver
Navigon 2100 mn6.exe fatal error message....going through update with card reader through navigon site didn't work...asme message. machine works. it seems to be card. how do I fix this or get a new...
Jan 07, 2010 | GPS
The MN6.exe fatal Application error is displayed all the time and I am unable to use the Navigon 2100 GPS
Dec 20, 2009 | Navigon 2100 Portable GPS Receiver
I HAVE A MESSAGE ON MY 2100 GPS,SAYS MN6 .EXE HAS PERFORMED AN IL
Sounds as if the system software that runs the GPS has been corrupted. Your device should have come with a CD that has software that can be reloaded or a utility that can be installed on the PC that connects to the navigon website to download and install the software for you.
Might want to start with that.
Hope this helps
TankMurdock
Apr 24, 2009 | Navigon 2100 Max Portable GPS System
Mn6.exe error
Sounds like the data on the sd card is corrupted.
You have to reload all data on the card,everything is on the navigon website,sorry i don't have the link).
You have to register before you can use their site.
Process is slow so be patient.
You should also format the sd card before reloading the data ( FAT,not FAT32).
process goes a little faster if you use a card reader.
good luck
Jan 31, 2009 | Navigon 2100 Portable GPS Receiver
I've had my Navigon 7100 GPS for 2 weeks now, little use, and today I got the fatal application error that MN6.exe was going to shut down. I have seen forums on this issue but nothing recent. The unit will...
I solved this problem.
The backup is just a copy of the files on the SD card. I made one a couple of months ago when everything was working ok. I tried to erase the SD card so I could restore the backup manually. I ran into an error with a SD card file that wouldn't erase. I ended up formatting the SD card then copying the old backup files to it. That took care of the problem and now the Navigon works the way it's supposed to.
Jan 21, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Navigon GPS
if your sd card is OK, there should be an update program on it, you have to go to windows ce on the unit to run this program. to do this hold the bottom right key while booting...
Jul 20, 2008 | Fine Digital FineDrive 400 GPS Receiver
Navigon 2100 Portable GPS Receiver Logo
Top Navigon GPS Experts
perdue40
Are you a Navigon GPS Expert? Answer questions, earn points and help others
