Question about Kenmore 64802 Top Freezer Refrigerator
Freezer works but fridge not cooling enough - Kenmore 64802 Top Freezer Refrigerator
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 30, 2010
Fridge works fine freezer doesnt freeze
Have it serviced/checked.
There is only one cooling unit in the refrigerator. It is rejecting enough heat to keep the fridge cool but not enough to keep the freezer cold.
Feb 12, 2015 | Maytag Refrigerators
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
The cooling unit stops running periodically.....long enough to allow food in the freezer to thaw. The fridge light is on, so electricity is getting to the fridge. The previous tenant had dogs, and when we...
Could be defrost sticking or the compressor not starting...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
The fridge is not cold enough although the freezer seems to work
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2010 | Smeg FAB32 Bottom Freezer Refrigerator
Freezers too cold leaks h2o to fridge now fridge wont cool
because of too less gas in the system it cant make cool enough too switch off the compressor
May 10, 2009 | Refrigerators
Jenn-Air JFC2089HES (French Door) Fridge not cooling enough
Hey Northrock,
Did you ever get your fridge fixed? I have the exact same fridge and the exact same problem.
Nov 22, 2007 | Refrigerators
Kenmore 64802 Top Freezer Refrigerator Logo
61 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
