Need to replace cartridge 2-3 days - Office Equipment & Supplies
  • 5,081 Answers
Pleasegive your brand and model number of your printer to give you the procedure on how to replace catriidge in them.
Posted on Aug 30, 2010
Print output is coming out fuzzy.
Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 04, 2011 | Brother MFC 420CN All-In-One InkJet...
Need all steps in changing black ink cartridge
Hi Good day!!! Here are the steps how to replace cartridges
1. Turn on your Epson Stylus NX100 Series printer. Your printer should be plugged in and connected to your computer.
2. Lift open the scanner and prop it up with the support bar. Press the stop button on your printer. The print head will move along the printer and will stop to show you which cartridge is low and needs to be replaced.
3. Press the stop button once more. If other cartridges need to be replaced, the printer head will indicate which ones by stopping on those cartridges each time you press stop. If no other cartridges need to be replaced, the print head will move replacement position on the right.
4. Squeeze the tab on the cartridge that needs to be replaced and remove the cartridge by lifting it straight up. Dispose of the used cartridge immediately.
5. Shake your new cartridge several times before removing it from the package. Remove the cartridge from the package without touching the green chip. Take the yellow tape off the bottom of the cartridge. Insert the cartridge into the holder by pressing until you hear it lock into place.
6. Release the support on the scanner and put the scanner back into its original position. Press the stop button to let your printer know that you have changed the cartridge. It may take up to two minutes for your printer to be ready to use. When the "On" light stops flashing and remains on, you may begin to use your printer.
Don't forget to vote thanks!!!!
Nov 02, 2010 | Epson Stylus NX105 All-In-One Printer
HP 8250 Cannot Print - Printer Senses New Ink Cartridge as EMPTY
you need to have authentic hp cartridges,if you bought cheaper,it will not work.
Apr 23, 2017 | HP Photosmart 8250 InkJet Printer
The Xerox Phaser 6180N Laser Printer won't let me print only black if the other 3 colors are empty. Is there something wrong and is there a away to fix it?
These printers need to 'think' they have a full set of useable (ie not exhautsed) cartridges.
There are two solutions.
1 Obvious really - replace the 'empty' cartridges - good quality remanufactured ones are available these days.
2 Replace just the chips on the cartridges (much cheaper than replacing the cartridges. There may still be some toner in the cartridges, and the colours may print for a while, but this is really only either a stop gap solution, or OK if you ONLY need to print in black.
Apr 09, 2010 | Xerox Phaser 6180N Laser Printer
Won't print after replacing cartridges
The following text copied from HP website to tackle this problem. minimtop.gif Follow the instructions below to install the print cartridges. NOTE: If you are installing ink cartridges in the unit for the first time, be sure to use only the print cartridges that came with the unit. The ink in these cartridges is specially formulated to mix with the ink in the print head assembly at first-time setup. s.gif Installing the print cartridges minimtop.gif
  1. Verify that the unit is on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00718797.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00721793.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
  4. Remove the new ink cartridge from its packaging.
  5. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot. NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted. Figure 3: Inserting an ink cartridge c00721795.gif
  6. Press down on the gray latch until it clicks into place. Figure 4: Closing the gray latch c00721796.gif
  7. Repeat steps 3 through 6 for each ink cartridge that needs to be replaced. NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  8. Close the ink cartridge door. Figure 5: Closing the ink cartridge door c00718798.gif
s.gif s.gifHave a Good Day
Jul 17, 2009 | HP Photosmart C4580 All-in-One InkJet...
Hp 750 printer cartridge replacement
For replacing the cartridge find out the useful information from the Official website of HP, by using the given link:
1. Check out the alignment of Cartridge use this link:
Alignment
2. Replacmenet of Cartdrige
Replace and Cleaning
3. Download the Manual for clear instruction
Manual
Best of luck and Have a nice day.
Regards Puneet
Oct 05, 2008 | HP PSC 750 All-In-One InkJet Printer
Printing Blank Pages
If the cartridges are original, your unit needs qualified service.
Oct 23, 2007 | Samsung CLP-500 Laser Printer
15 people viewed this question
k24674
jasbo
jasbo
