Question about Ryobi Garden
A cloth like bag that fits a weed eater for vacuuming up leaves
  • 490 Answers
Howdy, if you tell us the make and model of your unit, we can help you find accessories for it. Regards,
Farmerbear
Posted on Aug 30, 2010
How to get dog smell out of xl2600hh
Denise,
You need to do a bag wash of your outer bag. You will need to take the bag dock off if you have one of those on your vacuum or take off the "U" shaped clip if you do not have a bag dock and then pull the bag off of the connector assembly. You will also need to remove the plastic part at the bottom of the bag, you can usually use a flat blade screwdriver to pop that plastic part off. Turn your bag inside out and if you have a canister vacuum, vacuum the bag off the best that you can. If you do not have a canister vacuum, you could hose the bag off with a spray nozzle to get rid of any excess dirt. You then want to soak the bag in hot water with the Oreck Enzyme Odor Eater or with a good quality soap. I work at an Oreck store on weekends and we do this frequently. The Enzyme odor eater works great and leaves a nice smell behind in the bag fibers. We usually soak it overnight and then rinse the bag real well and then let it hang dry. If it is a nice sunny day, you can hang it outside and it should dry in 3 to 4 hours. Then you just reverse the process to put everything back together. Hope this helps!
Aug 11, 2015 | Vacuums
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
How do you attach the bag to the barracuda 2595 blower
The motor housing has a spring loaded, hinged cover over the fan blades (so you don't chop your fingers off when using it as a blower). Open the cover using a screwdriver or narrow tool. Holding the cover open, attach the vacuum tube. Attach the collection bag to the discharge port (same place you attach the blower tubes) and secure in place using the velcro strip sewn onto the bag. Adjust the ******** the bag to fit your shoulder, turn power on and go. To empty the bag, just unzip the bag completely. Make sure you tighten the velcro strip so the bag doesn't come off while you are sucking up leaves.
Oct 11, 2011 | RTO Weed Eater Electric Barracuda 2595...
Need to switch weed eater barricuda from blower to Vacuum but no manual
http://lawnandgarden.manualsonline.com/manuals/mfg/weed_eater/2500_series.html?idRes=15826113
Here is where you can find the manual to download for the 2500 series Weed Eaater blower/vac
Aug 29, 2011 | RTO Weed Eater Electric Barracuda 2595...
Need bag for weed eater electric blower Vac EBV215 model
Here is just one of many I'm sure that you can purchase online. The part number is listed with the price. This site is a little pricey so you may want to look around. Ebay sellers probably have them and at a lower cost.
http://www.ereplacementparts.com/vacuum-bag-kit-fits-types-p-229821.html
Nov 24, 2010 | Poulan Garden
I inherited two different blowers. i can't see how the only bag i have can fit on my weed eater barracuda 2595 and can't find any diagrams on line. once i open the spring door the bag doesn't really fit...
OK this may seem difficult but its really not. The spring door there are only 2 things to do with it open. Either you put in the round circular attachment and then close the door or you attach the bigger of the 2 "funnels."
The big funnel is used to **** up the leaves and it will NOT work WITH that circular attachment attached. The Barracuda will NOT blow leaves without the circular attachment.
If you want to blow leaves, open the swing door, put in the circular piece with a twist to keep it in place, close the door and attach the smaller "funnel" to the smaller opening on the front side of the blower.
If you want to **** up leaves open that swing door, take out the circular piece HOLDING OPEN the swing door and in that same place attach the larger "funnel". Where the smaller funnel goes is where you attach the bag! There should be a small opening in the bag with a velcro strap. Put that over the opening of the blower, attach in place with the velcro and your ready to **** the leaves! When putting on the bag, make sure the bag shoulder strap is facing the top of the blower, not the swing door.
Hope that helps. Now on to find the solution to my problem!
dlandlrd
Oct 30, 2010 | RTO Weed Eater Electric Barracuda 2595...
Looking to replace my vac, bag if possible
Oct 29, 2010 | RTO Weed Eater Electric Barracuda 2595...
Where can I obtain a replacement vacuum bag (in Calgary). The zipper on mine has broken making it unuseable.
Go to http://www.ereplacementparts.com/weed-eater-parts-c-17589.html Enter your model number. Then click one of the thumbnails that comes up until you find the replacement bag. My model number was 2595. I clicked on the thumbnail in the top row on the right and found the bag (part # 15). You can order direct from them and they ship right to you.
Sep 29, 2010 | RTO Weed Eater Electric Barracuda 2595...
How do I attach the vacuum bag and get it to work
There should be an air intake grille of some type, the bag should have a round opening that fits over a collar around the air intake, it may be held in place by a Velcro strap.
You don't give much detail to go on.
May 25, 2010 | RTO Weed Eater Electric Barracuda 2595...
I have a Weed Eater Barracuda leaf blower but don't have the manual. How do I attach the vacuum bag?
http://72.3.225.179/manuals/545117523e.pdf
Copy and paste. It will take you to .pdf for your Barracuda
Apr 30, 2009 | RTO Weed Eater Electric Barracuda 2595...
Garden Logo
42 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
