Question about Mitsubishi MS-A09WA Split System Air Conditioner
I have 2 of these units that are heat and ac i need to know if and where is the reset we had a power surge now they will not turn on at all
  • Mitsubishi Master
  • 43,501 Answers
The reset is to cycle the power.... turn off again for a few minutes and then turn back on.... but you may have blown a cicuit baord..
heatman101
Posted on Aug 30, 2010
Although I know it is not recommended, I have no choice but to plug my AC into a surge protected power bar/extension. I have done so for the last 2 summers, no problem. I take out my AC to install, last...
The best thing I can tell you is, that Danby does not recommend it. Even an extension cord is not recommended, unless it is a 14 gauge and no longer that 6 feet.
Several questioners in the past, have used a surge protect power bars and ended up frying the electronics of their AC units.
But, in the end, it's up to you.
Jul 13, 2011 | Danby Portable Air Conditioner
I believe my tv was involved in a power surge. red/green blinks
Hello:
U just may of blown fuses on the power supply of the television if you are sure it was a surge. If u can open the unit check all fuses on the power supply for open coniditions. If the future is a good Ideal to use a surge proctector as this will protect your equipment. Make sure power is off and remove AC power to check fuses. Sometimes just removing AC power for a least 2mins will reset the unit.
Jul 02, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
After not using my wii for about a month i went to play it the other day and it wouldn't turn on. The indicator light on the power button is off, not green, red, or orange. All the cords are connected, I...
Unplug it from the wall outlet (NOT from the Wii). Leave it unplugged for a good 5 to 10 minutes. The AC adapter needs to be reset (more on that below).
Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 03, 2009 | Nintendo Wii Console
Wii work for 3 weeks will not turn on .
There is no light on the front, correct? No red, yellow or green?
Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii. This is a common problem with the Wii. It happens almost every time there is a power surge or the power goes out, etc. Even if it's hooked up to a surge protector, this happens.
Power will come back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Nov 30, 2009 | Nintendo Wii Console
The game has no power but before we bring it back we would like to get the game out
It's likely not the Wii, it's the most likely the AC adapter. It needs to be reset. This is a COMMON issue after a power blip, surge, or outage (or it is way unplugged abruptly, or countless other things). If the below works, there no need to reutn the Wii. It's a common issue, the AC adapter just needs to be reset.
This is a common problem with the Wii. As I mentioned above, I'm very surprised Nintendo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc. Even if it's hooked up to a surge protector, this happens. The power comes back on, but the Wii appears dead.
Nov 25, 2009 | Nintendo Wii Console
Everything is plugged in, and it wont turn on
It seems even 5th or 6th problem is this. The AC adapter needs to be reset. Unplug it from the wall outlet for 5 to 10 minutes (NOT from the Wii, it HAS to be from the wall outlet).
Nov 22, 2009 | Nintendo Wii Console
Trying to change fuse in wii but need to know where to find it
Is your Wii just not turning on, no indicator lights? No red, yellow, or green, and pressing buttons doesn't work? Try re-setting the AC adapter.
Nov 21, 2009 | Nintendo Wii Console
The power button...console will not turn on. No
I see this issue on every site and Wii forum I visit. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
Nov 16, 2009 | Nintendo Wii Console
No Power/ No light
You need to reset the AC adapter (I'll explain below)
Nov 14, 2009 | Nintendo Wii Console
My wii won't power up. I am not sure what is wrong, but it won't turn on.
I just posted this somewhere else where this was asked, but I'll post it here too so it helps other people.
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
Aug 05, 2009 | Nintendo Wii Console
Mitsubishi MS-A09WA Split System Air Conditioner Logo
384 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
