Question about Microsoft Windows XP Home Edition
To know about software
Respected sir,
I want to know about some downloadable software which can convert Autocad drawings(DRW files) to g-codes and m-codes for CNC controllers.
  • Anonymous May 08, 2008
    how can ping vertual p c and portable p c
My autocad dwg files have been corrupted
Displays a list of all drawing files that were open at the time of a program or system failure. You can preview and open each drawing or backup file to choose which one should be saved as the primary DWG file. After a program or system failure, the Drawing Recovery Manager opens the next time you start the application. Drawing Recovery Manager displays a list of all drawing files that were open. The System Variable RECOVERYMODE controls whether drawing recovery information is recorded after a system failure and whether to show the Drawing Recovery Manager or not.
If you want to help yourself, Autodesk and other AutoCAD users make sure to send in any errors to Autodesk when you see the Customer Error Report dialog box (CER).
Finally a solution that sometimes helps if AutoCAD cannot fix the problem is to try to fix the drawing in another program that can open and save DWG files. The more users having the similar problem the better chance it will be fixed in a service pack or future version. Eventually you might
get DWG Restore Toolbox saying the problem is fixed.
from website: http://www.dwg.restoretools.com/
Jun 20, 2015 | Autodesk AutoCAD 2010
How to view damaged dwg file of autocad?
Try using a different version of AutoCAD to open the drawing, such as AutoCAD 2013 vs. AutoCAD 2015 or plain AutoCAD vs. AutoCAD Architecture, etc. Try different computers if available. or try DWG Viewer Tool on website:http://www.ask.com/answers/722146801/how-to-view-corrupted-autocad-drawing?qsrc=14106
May 29, 2015 | Autodesk AutoCAD Electrical 2013
How do i fix autocad? Please help!
You can fix this problem in two ways.
First: follow these steps
- Open the Registry Editor by typing "regedit" in the Windows 8 Search charm and selecting "regedit" from the Apps section of the search results.
- Navigate to the "HKEY_LOCAL_MACHINE\Software\Autodesk\AutoCAD\R15.0\ACAD-1:405\AdLM\Type" registry key.
- Right-click on the registry key and click "Export."
- Choose a name to save the license registry key file as, along with a location where you want to save it, and then click the "Save" button.
But if it useless try the second way- DWG Fix Toolbox. http://www.autocad.fixtoolbox.com/
Dec 23, 2014 | The Computers & Internet
Can you convert micrografix draw files to another file format
Each Micrografx Designer 3.1 *.drw file should hold one page of drawings, and that one page should be at page 1 in the Micrgrafx layout.
Corel Designer Technical Suite X5 has a free 30-day trial period. This program will import a Micrografx Designer *.drw file and let you SAVE AS or EXPORT AS an *.svg file.
Many current drawing programs, e.g., Visio, can import this *.svg file and let you save as a *.vsd file.
But if your *.drw file contained many pages of drawings, your converted file will have many pages of drawings but often in a single large page that you cannot edit. So safer to start out with *.drw files that each contain one page, and that one page should be drawn at page 1 within Micrografx Designer.
I have used the above method to convert very old Micrografx Designer 3.1 *.drw files to Visio *.vsd files. One problem was the Greek letters that were italics in the *.drw file are not italics in the *.vsd file.
Dec 15, 2010 | Micrografx Windows Draw Graphics & Print...
Autocad 2004 and win vista
Apparently, autocad is not compatible with vista.. Might as well, go back to wndows xp.. Please see the required specs to run autocad 2004
Mar 22, 2010 | Autodesk AutoCAD 2004 for PC
How do you lock a dwg file so it cannot be edited?
A COUPLE OF SUGGESTION
Now you can protect your works with this DWGLock software, the entities in the send out drawings can NOT be copied nor changed. However, recipients can open up the drawing, add lines and markups. Only the drawing owner allows extracting the drawing, if they need to, enclosing the added part with the native drawing. This is ideal solution for the collaboration needs and contractors.
It is a stand-alone application, no AutoCAD required; Supports AutoCAD R2.9 thru 2009 drawings. about $330.
CADLock, Inc. continues to create innovative solutions that enable you to maintain control of your intellectual property and share it with those who need it. We invite you to download and evaluate CADVault® for AutoCAD® to find out how digital rights management can work for you. THIS MAYBE PRICY also
Acme CAD Converter Acme CAD Converter is a dwg/dxf/dwf format conversion software for batch and vector files. It can conveniently convert DXF,DWF and DWG files into BMP, GIF,JPEG, DXF, DWG, SVG , PDF, HPGL etc., and also enable the conversion between DXF and DWG file versions (R2.5-R2005).
Apr 01, 2009 | Autodesk Map 3D 2006
AutoCAD LT 2008 (xref circular references)
The "circular reference" indicates that the xref you are pulling in is also xrefing the drawing file you are in which creates this circular reference to each other. The error message is only a warning and does not prevent you from working and saving changes. To get rid of the error message, close the primary drawing file and then open the reference drawing and DETACH the xref that is linked to your primary drawing. Save the changes and then open the primary drawing file again to see if the error was resolved.
Mar 16, 2009 | Autodesk AUTOCAD LT 2008 SLM 10 SEATS...
Respected sir,
It cannot be set as desktop background...
Powerpoint presentation file extention is .ppt
while desktop background file extension are.. jpeg, jpg, bmp, gif......etc
.gif file is the animation file.
U can use the software to convert .ppt to .gif and hence set it as desktop background.
Dec 20, 2007 | Computers & Internet
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
