Question about Black & Decker Black And Decker Pivot Drill/driver
What is trick to changing the bits? i unlock it but cant get it out
  • 490 Answers
I think it is an issue of having to pull real hard with that model. The hex bits stick a lot especially when new or using another brand of bit. Hope this helps a little:)
Farmerbear
Posted on Aug 30, 2010
Is there a way to et my antitheft lock off of my radio when i cant read the display?cant enter my code.
call dealer with vin# and see if they can help provide code to unlock some times there are little tricks that only dealer knows good luck!
Dec 12, 2013 | Vehicle Parts & Accessories
Sercurity light flashing car won't start. Tried spare key
spare key may be a valet key and will not turn off security, try locking the doors and using the key in outside lock -unlock, or unlock and hold, double tap. play with it a bit each manufacture makes there own little tricks, good luck
Nov 05, 2012 | Cars & Trucks
Wich version of google chrome supports cooliris/win7 sys64
Make Google Chrome Work on Windows7 64 Bit
Right Click on the Google Chrome Shortcut Icon
Click on Properties and Select the Shortcut Tab From the properties Window
In the Target Field put -in-process-plugins right after chrome.exe
Click On Apply to save the changes and Then Click on OK to close the window
Now Open Google Chrome It would work on your Windows 7 64 Bit.
http://www.chromeplugins.org/tips-tricks/how-to-run-google-chrome-on-windows-7-64-bit/
hope this helps
Oct 10, 2012 | Acer Aspire Z5771 23 Inch Touchscreen...
I cant unlock my phone, cause i cant remember the unlock pattern
If you keep trying the to unlock it, it will block and ask for your gmail account to unlock it. That should do the trick.
May 22, 2011 | HTC Hero Smartphone
2003 Santa fe fuel filter.....
dear friend:if you got the filter unit in your hand then clamp the metal part in a vice and unscrew the filter part,sometimes it appears that it cannot seperate but it can.force and a filter remover will do the trick
Sep 22, 2009 | 2004 Hyundai Santa Fe
NEED TO UNLOCK nokia 6300
Try these steps may help you...
First Trick : For Master code calculation http://www.nokialockcode.com/calculate.php and enter it to unlock. For IMEI *#06#
Second Trick :
1.press "unlock" button
2.then press "back"
3.then deep press unlock and then suddenly press *
4.that's all you unlocked the phone successfully.
NOTE: it will not work on all nokia phones so please check the nokia phones before practising the trick;but the trick can effectively work on most non java enabled nokia phones
Third Trick :
Remove Your Sim Card, Power The Phone On
Press # From The (Insert Sim) Screen
Enter codes WITHOUT spaces.
Press * 3 times fast for (p)
Press * 4 times fast for (w)
Press * 2 times fast for (+)
Verify code before pressing the last #
Fourth One:
The only way you can reset the security code is to take it to Nokia or some mobile store where they will reset it using a flash cable.
Hope you will resolve your problem.
Nov 20, 2008 | Nokia 6300 Cellular Phone
I HAVE FORGOTTEN MY SECURITY CODE F6R 0Y N625A 6288
Try these techniques
Second Trick :
2.then press "back"
Third Trick :
Fourth One:
I hope this will help you.
Nov 18, 2008 | Nokia 6288 Cellular Phone
UNLOCKING NOKIA N73
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot. The trick is by switching off the phone then press and hold Call key (Green key) + * key + 3 key + power button for a couple of seconds
but all your data will be lost
Aug 18, 2008 | Nokia N73 Cellular Phone
I cant fit my phone case help plz!
try putting on the front first, soemtimes the trick to those cases is the front must go on first. where ever you bought it should knwo the trick. was it a service provider store or liek walmart or soemthing?
May 30, 2008 | Sony Ericsson K550i Cellular Phone
CANT UNLOCK MY MOTORIZR
Hey Valla,
here's a little trick for you. When it asks you for your unlock code, press the menu key. The phone will now ask you for your security code. Unless you've changed the security code, it should be "000000" (six zeroes)
If it's still the default, you'll be able to access your unit. :D
Hope this helps,
cHiPz.
Mar 30, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Black & Decker Black And Decker Pivot Drill/driver Logo
113 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
