Question about Acer Aspire™ T180 PC Desktop
Acer Aspire T180 PC Desktop fails to boot
Windows vista attempts to load then the system restarts, the recovery console doesn't work either (system restore etc) it just restarts the PC again. I have no backups or no Vista disc. It wont boot at all.
  • 3 more comments
  • Anonymous May 09, 2008
    Acer Aspire T180 PC Desktop fails to boot problem
  • psycowenchie Oct 24, 2008
    Same issue at the other guy. Though I can't get off the screen that says ACER. F12, Delete or Alt F10 don't do a thing.. I need some sort of boot disk.. I think
  • number9score Oct 25, 2008
    tries to boot xp (media centre edition?), shows Acer screen then windows screen then goes blank again and seems to power off, show "no signal" message on my acer monitor and go through the same loop again...
  • Anonymous Mar 24, 2014
    vista home premium,often my num lock light will stay on after booting up, freezing my key board, hence I have to restart my pc.
  • Anonymous Mar 30, 2014
    showing incompatible file system
  • 3 Answers
You can use ERD commander to boot the system, backup your files to any other partition except first partition.
I am sure you have software related problem.
Posted on May 08, 2008
Error message that says boot disc error. there is
This is either a corrupt file system or a bad hard drive. You'll need to boot from a Rescue CD like BartPE or a Windows CD and run chkdsk on the drive to see if the file system has just become corrupt. If that fails, you may need to run "fixboot" and "fixmbr" from the recovery console. If those fail, or if chkdsk comes back and says it can't repair the damage, then you probably need a new hard drive.
Mar 19, 2010 | Acer Aspire™ T180 PC Desktop
I need to wipe my acer aspire pc with vista. Do I need a recovery disc I do not remember it coming with one?
You can do it without disk to but for it should be hiddden partition is installled when your vista is load first time.For that
There is one option in bios D2d enable it .then save settings.
For enter bios when you power up the computer press F1 or F2 or "del" key then go to main menu find D2d
then enable then save and exit.
Then when it restart press ALT +F2
then you see recovery mode follow the procedure and wiped acer.
But if there is not any recoverry then you need recovery disk.
Let me know if you need more assistanse.
Thanks.
Sep 16, 2009 | Acer Aspire™ T180 PC Desktop
Acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jun 22, 2009 | Acer Aspire 6920 Notebook PC
WILL not resetting to factory settings
You will need to burn a Recovery CD / DVD set from the icon located on the desktop/ In your Acer Home Start utility (The window loading at startup) or from the Start Menu.
Using this disk you will be able to do a System Restore back to original factory setup.
Apr 14, 2009 | Acer Aspire T180 PC Desktop
Acer t180 boots to erecovery
Borrow any Vista install DVD and boot from it
Follow it through until you are asked if you want to install Vista or Repair your Computer
Select repair and let it do its thing - it may work
Failing that its a full reinstall by the sounds of it
If it does not offer you the initial boot option then look on the boot screen for the boot options key - probably F11 or F12 - and press that during initial boot to obtain the boot options screen
Dec 19, 2008 | Acer Aspire™ T180 PC Desktop
How do i fix my acer windows vista computer
I wiped out my Acer Aspire T180 , bought the system and recovery disc from Acer but after loading them it starts to load windows vista little bar goes across with the green in it then the vista backround then a box will pop up saying , there was an unexplained error and windows restarted unexpectedly so you need to restart windows now but then get the same box all over again. HELP !!!!!!!!!!!!
Oct 18, 2008 | Acer Aspire™ T180 PC Desktop
Boot up
Hi Jen05.
When the computer boots, if it asks for an O.S.
(operating system) hilghlight "Windows Vista" and press enter.
If it asks whether to run Windows Vista or something like:
"Windows Recovery Console (reccomended)", select Windows Recovery Console. Follow the steps until it asks if you wish to run System Restore. Click the appropriate response that basically denies this suggestion. Let it go through the steps (you may need to press "Next").
Once it is done, restart Windows as you normally would.
If the problem persists, try the following:
(operating system) hilghlight "Windows Vista" and press F8.
Now scroll down to something along the lines of:
"Safe mode - core drivers only" and press enter.
When it loads the desktop, it is normal for there to be incorrect graphics, missing desktop image, etc.
Now virus scan the entire computer with every anti-virus and spyware software you have. Fix problems found with the programs as needed. Now reboot the PC as you normally would.
If it STILL doesn't boot correctly, or at all, please say so;
I am willing to provide all my knowlege to help as much as I can.
Jul 31, 2008 | Acer Aspire 5050-3242 Notebook
How do you reset Acer Aspire T180-GB7Z PC
Perform a system recovery:
Does not come with recovery cd's - there is a program that allows you to burn the disks or
recover.
3 ways:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Or click on Burn disks instead of restore
3. if unable to ge into Windows then Alt/F10 during boot right after Acer splash screen on startup
End User Technical Support and Service (USA only)
For end user technical support, spare parts and service: 1.800.816.2237
Dec 30, 2007 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
409 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
