Question about Westinghouse Dishwashers
No heatinh - Westinghouse SB925SJ*00 - suspect dual water sensor (Water presence and temperature). Require price and availability. Thanks.
  • Westinghouse Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 30, 2010
What are the pros of Marey Power Gas Tank less Water Heater?
The pros of the Marey Power Gas Tank less Water Heater are as follows:
1. Available in propane and natural gas
2. DIY installation process optional
3. Very reasonably priced Does not use electricity but does require a 2 D-Cell battery
4. Only uses gas, when water is turned on (decreases natural gas wastes)
5. Equipped with easily adjustable gas and water knobs
6. Digital display makes it easy to read water temperature
7. Very compact design
8. Works great with low water pressure levels
You can have more information about it like how it works and installation process etc.
Jun 23, 2017 | Water Water Heaters
Im looking for intelliseat toilet temperature sensor
IntelliSeat - the Ultimate Bidet Electronic Toilet Seat, Bidet Seats ...
https://www.amazon.ca/IntelliSeat-Ultimate-Bidet-Electronic-Toilet/dp/B0050EJBQ0
  1. Cached
IntelliSeat - the Ultimate Bidet Electronic Toilet Seat in Bidet Seats. ... Bio Bidet BB-i3000 Premium Dual Temperature Bidet Toilet Seat, White · 4.3 out of 5 stars 18. CDN$ 179.00 .... Maybe the sensor on the Seat is not working? I am contacting ...
Intelliseat Bidet Toilet Seat - Proper Wash
www.properwash.com > Electronic Toilet Bidet Seats
  1. Cached
  2. Similar
IntelliSeat, is one of AMDM's featured innovations bidet toilet seat, and after one use ... Toilet sensor permits operation only when skin contact is made ... Water Heater; Endless Warm Water; Heated Seat (adjustable temperature); Increased ...
AMDM IntelliSeat the Ultimate Bidet Electronic Toilet Seat - Amazon.com
https://www.amazon.com/product-reviews/B0050EJBQ0
  1. Cached
However, if you have a newer elongated toilet, the Intelliseat will probably fit just fine. ... Maybe the sensor on the Seat is not working? ..... Both seats have LED indicators for seat temperature and water temperature, but only the Intelliseat has ...
Intelliseat is a must for modern toilets - Pilot Bidet
pilotbidet.com/intelliseat-is-a-must-for-modern-toilets.html
  1. Cached
  2. Similar
IntelliSeat is one of the most advanced toilet apparatuses and after one use you ... These sensors can sense the presence or absence of a human body on the ...
=$= AMDM IntelliSeat - The Ultimate Bidet Electronic Toilet Seat w ...
https://betojhkitchenbath.wordpress.com/.../amdm-intelliseat-the-ultimate-bidet-electro...
  1. Cached
Mar 20, 2013 - AMDM IntelliSeat - The Ultimate Bidet Electronic Toilet Seat w/ ... Water Glow LED Faucet Light with Temperature Sensor Three Optional Colors ... intelliseat toilet temperature sensor Google Search
Dec 04, 2016 | Ovens
Pool heater throws code h5? smoked
HS
Water Temperature Sensing Error
A) Inlet water temperature sensor is reporting a temperature in excess of 104 degrees.
Normal operation resumes 2 minutes after inlet water temperature sensor reports temperatures of 104 degrees or less. This error functions in both normal and remote thermostat modes.
or
B) Inlet water temperature sensor is reporting a temperature change at a rate faster than 6 degrees in 60 seconds, indicating a potentially damaging low water flow conditon. Normal operation resumes when temperatures stabilize. If this condition is detected 3 times, the heater will lock-out until the electrical power is cycled off and back on.
Jun 10, 2014 | Hayward H Series Pool & Spa Heater...
I have a 50 gallon power vent lp water heater. the water was under water this weekend. when i try to ignite the heater i can not see the spark at t he burner. When I remove the blue ignition wire from the...
Your power vent water heater with electronic gas control went under water.
http://waterheatertimer.org/Flooded-water-heater.html
I suspect the gas control valve is bad, and possibly the ECO and FVIR sensors shorted.
Repairs might require replacing gas control, eco, fvir, igniter, and then clean burner and combustion parts.
Open following link to identify typical gas valves: and possibly read service manual for troubleshooting that model.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Might be easier to replace water heater
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 30, 2011 | Rheem 50 GAL FVR Propane Gas Water Heater...
Error code e2. inlet water temp sensor. any one have to fix this?
Before calling service technician, open following link for Bosch troubleshooting resources, including error codes, manual, Bosch contact info, and service bulletins.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Error codes are starting point for troubleshoot.
e2 is cold water temperature sensor fault.
Bosch error code says: 1) Check connector on wires coming from top of water valve for a secure connection.
2) Sensor may trip if water temperature drops below freezing to protect heater from freezing conditions Any damage due to freezing conditions is not covered under warranty.
Another contributing cause can be temperature thermostat set very high and tankless sensor is going bad, and very cold incoming water, or combination of factors above.
Also read manual for advisories and required maintenance. Some units require water filter be cleaned monthly.
Upvote the help.
May 28, 2011 | Bosch AquaStar 2400ES-NG
I have a Bosch confort 13 tankless water heater in my Mexico home. I have had problems with consistent water temperature. My contractor told me they have problems with them down there...not sure if it...
Your contractor understand the market there, but problems are mirrored in US also.
As evidenced by fixya.
1) Tankless cannot be exposed to more than 11 grains hard water, and require minimum water flow and water pressure or sensors will shut down burner or element.
2) For example, tankless might turn on with 2/3 gallon-per-minute water flow, but then another faucet is turned on so pressure and water flow drop, and tankless turns off. Or neighbor's water usage causes decrease in line flow, so tankless turns off. This is called 'cold water sandwich.'
3) If problem is water pressure, you can add in-line pressure tank, but root causes vary widely with more than one factor as suspect.
4) Also incoming water temperature can be a factor, along with temperature setting of unit. Most tankless are preset to 120 degrees F, which is modest temperature and certainly not very high. If tankless cannot raise temperature of incoming water fast enough, then tankless turns off. Of course water flow continues, so you get dose of cold water.
You can add simple120Volt 30 gallon tank-type electric heater as a tempering tank that pre-heats water either passively or actively: http://waterheatertimer.org/Tempering-tank.html
5) Both internal and external factors affect tankless, with bottom line that these high-tech devices are not do-it-yourself repair for most people.
6) Install DIY tank-type gas water heater and avoid the whole headache
7) In my opinion, the genius of tankless is not that they save money or energy. Because they don't.
The genius is marketing that targets a certain affluent who believe tankless save money and energy.
http://waterheatertimer.org/pro-n-con.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 22, 2011 | Bosch Water Heaters
Numbers missing from Westinghouse oven knob, plus burner troubles
ok put a pan of water in your oven with a cooking thermometer in it. Turn your oven with the new knob you just got from repair shop. They are in the yellow pages Lots of laid of repair guys went out on there own. So they work at a lower price. As i was telling you.set your new knob @ 9:00 leave it there long enough to even out 10 minutes will do. next set it @10:00 next 11:00 @12:00 and so on. Till you get all your settings are compleat. Happy cooking from sawdust46
Aug 08, 2009 | Kitchen Ranges
Motor starts but no water entering dishwasher
TRy priming by putting a jug of water in bottom of inside of dishwasher
Mar 04, 2009 | Westinghouse Dishwashers
Fault F24 on kenmore front load washer
F24 error code a water temperature sensor error or enought hot water to the washer.
check to see you have both valves are turned on. Also, the water inlet valve on the washer has a screen and it is known to get clogged and restrict water flow. Turn off the hot water valve. Pull the hot water hose off where it attaches to the back of the washer.
Even if you are getting good hot water flow, inadequate water temperature can cause an F24 error code. Check the temperature setting on your hot water heater. It should be set at 120 F. You should reach this hot water temperature at your washer within about 1 minute.
If you are getting a good hot water flow, you may one of the following failures:
1 loose or dirty connection at the temperature sensor or control board.
2 The temperature sensor could be out of range. Bad or shorted sensor
3 Control board failure.
The temperature sensor should have a resistance reading of 6.6k ohms at 104 degrees F and should drop in Ohms as temperature rises,
The temperature sensor is located at the back lower section of the tub with 2 small black wires. It would require a ohm meter to measure the resistance of the sensor. .
Apr 20, 2008 | Washing Machines
Dishwashers Logo
383 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
