Question about Syntax Olevia 226T 26 in. LCD Television
On my Olevia 226-T12 I have volume, but no picture. I can also get closed caption. It happened overnight. When I turn the TV on the screen shows with the "Olevia" name on it and then it turns dark blue. I have no manual so I am at a loss.
  • starrchar Aug 30, 2010
    You asked if there is a dull glow on the screen. The screen is the normal deep blue that you see when the TV is on, but the cable box is turned off. I hope this makes sense.
    Yes. It was a bad cable box :) Thank you very much for your help.
  • 4,889 Answers
Sounds like you have a backlight related problem. Apparently the backlight is turning itself off in a few seconds.Can you confirm if you have a dull glow on the screen?
Posted on Aug 30, 2010
  • 7 more comments
  • eagle338
    eagle338 Aug 30, 2010
    That means the tv is not recognizing the input source. Did you try another input source such as DVD player to see if the problem persists? That will help us determine whether its a problem with the cable box or the tv itself.
    Thank you very much. It was the cable box. I switched it with another box and after a few minutes the TV picture came right on.
  • eagle338
    Glad to hear that its not a problem with the tv. Thanks for the accept and thanks for using Fixya!
    Sorry my rely showed up so mnay times. When I hit submit a message came up saying I needed to try again...and again and again and again! Thank you again very much for your help.
  • eagle338
    No problem.
My olevia tv 237-T12 turns on but has no picture or sound. Screen is on but blank screen. What can I do to fix this problem
to save money take it in for a proper diagnosis and quote
that saves you chasing problems that may cost more than a shop repair or unit replacement
Sep 16, 2016 | Olevia Televison & Video
Olevia 232 t12 lvds cable
It might be best to replace the LVDS cable along with T'Con.
Jul 09, 2013 | Televison & Video
I have an Olevia model 432-S12 flat screen TV and I cannot get the closed captioning to shut off. All help appreciated, pokerpadre
You should be able to accsess your menu by pressing the menu button on your remote. You can scroll around until you see a "CC" option. Select that and arrow up down or side to side to select turning closed caption off.
Apr 04, 2011 | Olevia 332V LCD TV
We get a black square on Fox and one children's cartoon network only. I have close captioning set off on my Uverse box menu. Is their anything else I need to do on the Olevia setup menu to eliminate the...
This is most commonly caused by the use of a Closed Caption text box. This type of Closed Caption is not always supported by the broadcaster, and results in the appearance of a black rectangle with scrambled or no text.
This can be quickly resolved by adjusting the Closed Caption type to "CC1" or by disabling the Closed Caption feature on your television.
get in the menu and change the close caption with the Olevia remote control
This should fix you right up
Dec 03, 2010 | Televison & Video
Can't turn closed caption off.
Go in ur tv menu go" Picture" go down to reset, press it the tv will back to factory setting.If the Captioning still there.Than ur Tuner Main signal board have problems.
Apr 04, 2010 | Olevia 237T 37 in. LCD TV
Need code for my Cox Remote Control for my 26-inch Olevia 226 T12
We had this same problem as well and we finally found the answer, the code for the COX remote (silver on top black on bottom) is 1240.
Feb 21, 2010 | Olevia LT27HVX 27 in. LCD Television
Problem with Olevia 226-T12 firmware install
the only thing is to keep trying it but you might want to leave the television off over night and then try it the next day.. also try doing the firmware on a 1G or less thumb drive...if the television is still not grabbing the firmware then it sounds like the television will need to get service... this means the television's main-board will need to be flashed.
Since the Manuf. of Olevia is out of buss the only company at this time that has the tool and parts to repair the television will be the 3rd party repair center called Amergence Technology ( 866-965-3842)
Jul 29, 2009 | Syntax Olevia 226T 26 in. LCD Television
Toshiba 32AF45 Black Rectangle Issue
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | Toshiba 32AF45 32" TV
ZzVzzVzzV on my screen
Sounds like a bad system board.  Start with Olevia for warranty status, and if it's not covered, check for part numbers on the boards for purchase/repair.
Oct 19, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Big black screen in picture
You have the CC (closed captioning) turned on and it is set to text mode. Look for a button on your remote labeled "CC" or go into your TV menu and make sure the captioning selection is set to "off".
Sep 19, 2007 | Televison & Video
Syntax Olevia 226T 26 in. LCD Television Logo
255 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
