Put a new one in. fine for a day or two and then bam, the red arrow is back.
  • 4,924 Answers
If you are talking about the cartridges ..than you should try to make a ink counter reset ..and to do that go in maintenance mode...than from the arrows choose reset counter ..and reset all counters you have there in the menu ..to be sure ..
to get into the maintenance menu ...try to hold down the menu while plugging the power cord(obvious that you should shut it down and unplug first ..than try that ..)
if this will not work try again with the front door open ...or ..look in the manual and see if there is described the exact procedure cause I dont know the make and model ..you never provided them ...
Posted on Aug 30, 2010
I have a 2000 jeep grand Cherokee Laredo 4.0. I believe it has some electrical problems, it starts and runs when it wants. sometimes it will start fine, sometimes not at all. sometimes it will run very...
Found that the outboard PCM cover screw was shorting out the circuit board. Chrysler PCM p/n P56028412, s/n TEH106636023.
Short story long: I have a 96 Grand Cherokee 4.0L, 125,000 miles. Several weeks ago, I started to have stalling issues. Hot or cold, dry or wet, first drive of the day or last, it didnt matter. The engine would cut out. It felt like it lost all electricals.
At the time it was showing an ASD relay code. Swapped the ASD and A/C relays. Same problem. I didnt have time to look at it, so I had the dealer go through it. After 2 days and $200, they called and said it was the ASD relay, and that they put in a new one, and its all good. Um, ok, maybe I missed something. Im a trusting soul, but lets see if this fixes it. The next day the problem was back. I went back to the dealer and they basically said, We dont know what it could be, good luck with that. Now my wife knows why I dont go to the dealer. By the way, the old relay tested good.
My turn. Being the methodical aircraft mechanic that I am, I grabbed a multi-meter, contact cleaner, and wiring diagrams. I cleaned connectors, ohmed out wires and sensors, checked for power and grounds. Everything checked good. By now, its showing ASD, crank sensor, and primary ignition codes. Then, with my wife trying to start it, I wiggled the connectors on the PCM. Every time I wiggled the gray C3 connector just right it would run. When I let go, it would die. So I took the connectors apart and tightened up the crimps (I dont recommend doing this without the proper extractors and crimper). Threw it back together and BAM! Same problem. Well, time to bite the bullet and check for bad solder joints on the PCM board. I took the cover off of the PCM and realized that looking through the potting compound is like looking through Guinness Stout. But, I put it back in and hooked it up. It started stronger than ever, and didnt even think about stalling. Yes! I figured that I finally got the connectors sorted out, so I left it over night to cool down. Got up the next morning and it started right up and wouldnt stall even when wiggling the connectors. So I put the cover back on, put the PCM back in, hooked up the connectors, and BAM! It wouldnt start! That was the point when my wife asked, Hows it going? And I, being the methodical aircraft mechanic that I am, said, what the ----? Thats when my wife turned around and went back into the house. While smoking a pack of cigarettes, I thought, Gee, it runs with the cover off, but not with it on. DUH, wonder what it could be? So I backed out the two screws that hold the cover on and BAM! It started right up. Then, while it was running, I tightened the outboard screw and sure enough, it died. Yes! Aircraft mechanics love it when they can make things stop working. I installed new screws (1/4 long, factory screws are 1/2 long Torx head), and shes been running great ever since
Aug 16, 2010 | 2000 Jeep Grand Cherokee
1995 ford escort lx;one day i put in reverse went 2 ft and bam it
you have got some serious drivetrain issues but please inspect the cv axles to make sure there not getting hung up somewhere
Jul 30, 2010 | 1995 Ford Escort
The red light on the front stays on but the camera won't work. i haven't dropped it or anything. It is a kodak easyshare CD43. It was working fine a couple days ago. I put new lithium batteries in and it...
he red light on the front stays on but the camera won't work. i haven't dropped it or anything. It is a kodak easyshare CD43. It was working fine a couple days ago. I put new lithium batteries in and it has the same problem as before.
Feb 14, 2010 | Kodak CD43 Digital Camera
I have a 99 isuzu trooper (jackaroo) 3.5 liter 4wd with torque on demand my jssue is the check rear wheel's lights blinks green then red if I put it in 4wd the rear wheel light indicator gose green the...
sounds like a sensor - when did it start - if just cranked up one day and bam it is there - sounds like either a brake wear indicator issue - if they are connected in those - or a fluid level change in the rear end or transfer case - look for leaks and check the brake pads or shoes
Dec 26, 2009 | 1999 Isuzu Trooper
Some time when i start my 01 blazer theres nothing and then bam
Check your battery cables and connections,if you access to an ohmmeter you can check them,clean any corrosion on the cable clamps and battery posts,pull the negative cable off the motor and clean it and the spot on the motor it bolts to.Place a lead on each end of the negative cable,you should get a 0 ohm reading or really close to it,any higher than 2 or 3 ohms and the cable is bad,repeat the procedure with the positive cable.Be sure to have the thecables undone from the battery,placing an ohmmeter on a live circuit will burn up the internal fuse or burn up the meter.If the cables check out good look to the starter solenoid.Hope this helps,
Apr 21, 2009 | 2002 Chevrolet Blazer
1997 chevy Cav, Intermittent starting issues
Might be something in your gas tank that gets stuck, I've heard of people putting whiffle balls in peoples gas tanks and that happens.
Mar 18, 2009 | 1997 Chevrolet Cavalier
Loud thumping while spinning
my friend had this happen,apparrently a bearing was leaking then finally broke!
Jun 25, 2008 | Frigidaire ATF6000ES Front Load Washer
My son's console stoped working
18004myxbox they will send you a box, put your 360 in it, wait 1 month and you will get a new 360. I am on my fourth 360 in 5 months. I just get used to one and then BAM!!! THE RED RINGS OF DEATH APPEAR!
Dec 09, 2007 | Microsoft Xbox 360 Console
12 people viewed this question
k24674
jasbo
jasbo
