AVG7.5 setup In my computer there wsa AVG7.5 Free set up but for some error it become invalid-pl. regenerate it
  • 57 Answers
Go here to download v.8.0 as 7.5 is about to expire.
Posted on May 08, 2008
Goes into "REGEN" at random, looses power/dies. Forced REGEN many times, still looses power/dies. ???
Nothing major remove all parts and fittings around regeneration sensor
There are two holes under regeneration sensor
They are clogged
Clean all the way to exhaust
This will solve your problem
Feb 22, 2016 | Cars & Trucks
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
How do I repair error 4480 when burning a dvd
Error Code 4480 and other serious malfunctions can arise when the Windows® operating system becomes overloaded with invalid system references, as well as corrupted and deleted registry files. These problems commonly occur due to a lack of regular PC maintenance. As a computer operating system gets older, errors and crashes start to become more frequent and problematic.
Try a registry cleaner like Advanced System Care
Speed Up Slow Computer Keep PC and Internet Secure Freeware Download IObit
Feb 28, 2015 | Toshiba Satellite Computers & Internet
Aspire 3690
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard drive.
  1. Verify your boot options are properly set in CMOS setup. We recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
  2. If your CMOS Setup has an option to boot from the LAN disable this option.
  3. If you have changed any CMOS settings, make sure to save and reboot the computer.
If this does not resolve the issue, try resetting the CMOS values to the default settings, save and exit.
Finally, if none of the above suggestions resolve this error go through the Invalid or Non System Disk error troubleshooting steps, which is related to this error message.
Dec 17, 2013 | Acer Aspire Computers & Internet
Cant set up
You need to insert the CD/DVD that came with your computer and boot from that.
Apr 24, 2013 | Dell Latitude D600 Notebook
Unmountable boot volume
If your notebook came with a Windows installation disk, you can fix the issue this way:
1. Insert the installation disk into your CD/DVD drive, and boot up your computer.
2. At the Welcome screen, hit the R key on your keyboard. This will launch Recovery mode.
You should now see a DOS prompt on your screen.
3. Type chkdsk /p and hit Enter. This will launch a utility that scans for hard drive errors.
The process may take some time, so be patient and allow it to do its job.
4. After the chkdsk is done, type fixboot and hit Enter to repair any damaged boot files which may have become corrupted. When prompted to choose "Yes" or "No," type Y for "Yes."
5. Type exit and press the Enter key to reboot your computer.
Assuming chkdsk was successful in fixing the disk errors, you should now be able to boot back into Windows.
If you do not have a Windows installation disk, but have access to another computer with a CD/DVD writer, you can download Hiren's Boot CD to help fix your corrupted boot drive.
1) Download the Hiren's disk image, and follow these instructions for burning the boot CD.
2) To ensure your system boots from the CD you've created, follow these instructions on how to set your BIOS to boot from CDROM.
3) Alternately, you can download a free utility that will create a bootable USB flash drive containing all of Hiren's tools. The above link also provides step by step instruction on creating a Hiren's USB drive, as well as how to set your BIOS to boot from it.
4) Boot the problematic pc from either your Hiren's CD or Hiren's USB drive.
5) Once you've successfully booted your system using Hirens, you will see a menu with a variety
of tools and utilities. Navigate to the hard disk tools menu, and run HDD Regenerator.
You'll need even more patience this time -- as HDD Regenerator is a bit more comprehensive in its error scanning than chkdsk. On the bright side, HDD Regenerator has a reputation for repairing disk errors that chkdsk was unable to.
Good luck, and I hope this helps!
Jan 08, 2011 | Dell Inspiron 6400 Notebook
How do I know if the HD is damaged? I suspected HD failure due to the following? computer won't start. It says, "invalid Boot.INF file." And then, it say "press Ctrl+Alt+Del to restart". What could it be?...
It is probably BOOT.INI. However, might be anything from a virus to manual mistake, altho this file should be hidden.
HDD Regenerator: http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Regenerator.shtml free trial will help you check the HDD.
Nov 12, 2009 | HP Pavilion 533c (P9939AR#ABA) PC Desktop
I get an error 6 the handle is invalid
While running setup or autorun file directaly from the CD error msg comes as:- The handle is invalid
Email :- kumar.sanjit@mahindra.com
Jul 24, 2008 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
