Question about Milwaukee Tool Milwaukee 2401 22 12V Li Ion Sub Compact Driver Kit
Drill has power the light works but the drill does not turn
Hi. I have a makita 08070 hammer. when I will start this the power light is work but machine not work
Australia Drill Battery offers a complete and comprehensive product line of high quality MAKITA power tool batteries. Our MAKITA drill batteries are designed to be fully compatible with the original cordless tools. http://www.drill-battery.com.au/batteryshop.php/makita_power-tool-battery.html
May 09, 2017 | Makita Drills
Charger only has a red light when do I know battery is fully charged??
depending on the model of drill, the indicator (if not colour / state changing) only indicates that the drill is connected to power.
hence with no indicator of a full charge, if you refer to the user manual for this drill it should tell you how long the drill should be charged for.
Jan 28, 2016 | Craftsman 14.4 volt Cordless Drill/Driver...
Makita instructions
Get the battery tested. The light draws a very small amount of power and will work if the battery is just about dead, but to operate the drill, you need a strong battery.
Jul 27, 2014 | Makita 18v Lxt Li-ion 1/2-in Hammer Drill...
Makita BHP452ZW light works but no drill power
Your most likely problem is the switch (PN 650583-6). When they go bad they will let power go to the LED light but it won't get to the motor. With a multi-meter, check the power going into the switch and coming out to the motor. If 18 volts are getting through to the motor then you may have armature (PN 619198-8) issues.
Nov 26, 2013 | Makita BDF452HW 18V Cordless Lxt Lithium...
No power on a fully charged batery why?
Users have reported problems with the charger and battery life on this drill. If possible verify the charger is working by swapping it with another or using a voltmeter on the plug.
If it is, the battery has failed and will not hold a charge. It is uneconomical to replace it.
Nov 22, 2013 | Craftsman 14.4 volt Cordless Drill/Driver...
Re: DeWalt 18V XRP Cordless Drill Driver. Should performance of the drill slow as battery becomes weaker? My drill works fine for quite some time then suddenly loses all power, even the light won't...
Yes. It's kind of like a flashlight when your batteries get low the light get dim, but if you replace the batteries light gets bright again. The drill will get weak as battery get low.
May 09, 2011 | Garden
Charger or ac adaptor not working?
Check the adaptor with a multi meter, 110 volts, if no get new charger as I did
Jan 25, 2018 | Drills
Need to replace 14.4 powe drill
I recommend replacing your drill and light with an 18V Ryobi "One+" Drill and light from from the home depot. It outperforms any battery powered drill I have ever used. You can also get it with lithium batteries that will last twice as long.
Jul 06, 2010 | Craftsman 14.4 volt Cordless Drill/Driver...
Milwaukee Tool Milwaukee 2401 22 12V Li Ion Sub Compact Driver Kit Logo
88 people viewed this question
Top Milwaukee Tool Home Fencing Experts
crkuc
R Daniel Wolfe
 Russ Hill
Russ Hill
Are you a Milwaukee Tool Home Fencing Expert? Answer questions, earn points and help others
