Question about Kenmore Dishwashers
I have a Kenmore Quiet Guard and it has stopped draining. The drain line is not clogged.
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Aug 30, 2010
How do I reset my panel for my kenmore precision dishwasher with quiet guard
Just hold the Start button for 3 seconds, and it should drain and shut down.
Sep 16, 2014 | Kenmore Dishwashers
Kenmore Quiet Guard is clogged on the bottom. Leaking water.
take out the bottom rack, pop out the center. use a snake on the drain. if not aviable us a wirer coat hanger. the water should go down. to top it off ad some draino or something like that. but rises your dishes before you put it in the dishwasher. remember a dishwasher is not a garbage disposal. run the dishwasher again i wish nothing in it. that will flush out the drain. then your good.
Jan 02, 2013 | Dishwashers
I have a Kenmore quiet guard 3 model: 665.74364k2 and serie F55202295. It is not draining properly. It works fine and cleans the dishes but when it goes to drain it leaks in my basement ceiling and vents.
i thought I responded to this.
make sure the air gap in the kitchen plumbing (if installed is clear). Also check the kitchen drain is not blocked. If using garbage disposer in sink, then make sure it is run before you start the dishwasher.
Jan 10, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Kenmore Elite Quiet Pak keeps stopping the wash cycle and flashes F 02
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 20, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore built in dishwasher drain quit working
if it looks somewhat like a elongated and cropped figure 8 it is what we around here call a clutch drive. if it looks like a 6 point star, it is a torx drive.. Be aware, the screws holding the guard in place may also be holding the pump in place under the unit. if so removing the screws would allow the pump to fall off the bottom of the unit.
If the unit washes, the motor and pump are working (the same motor/pump that washes the dishes also drains the unit)
if the motor is not running during the drain cycle, it is most likely the timer or a connection to the timer
if the unit is not running at all, it could be the motor or timer
if the motor/pump is working, I would first ensure the drain line is not clogged (pump may be trying to drain the unit and forcing the water out were ever it can due to a blocked drain hose, this would explain the water on the floor. I have found that when a drain line is blocked, it is usually blocked where the drain hose connects to the drain pipe under the sink.
let me know what you find and we will Fix Ya.
clarkco
Feb 06, 2009 | Kenmore 15121 Built-in Dishwasher
I have the Kenmore Plus Quiet Guard, just wondering about filters as the water is not draining?? Anyone know?
It sounds more like a failed pump.
Does it circulate the water while washing dishes?
You might check the junction where the dishwasher connects to your drain under the sink. Often, they empty into the garbage disposal.  The inside of that junction has a tendency to clog with food (especially grease) and the pump of the dishwasher doesn't produce much pressure, it is more designed for volume.
Jan 08, 2009 | Kenmore 24 in. 17602 / 17604 / 17609...
Drain Clogged
you might try pouring liquid plummer in the drain part and jet it set it shouold eat through whatever is in there
Dec 26, 2008 | Dishwashers
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Dec 09, 2008 | Dishwashers
Dishwashers Logo
375 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
