Question about Intel Desktop Board DQ35JO - Motherboard - micro ATX - iQ35 - LGA775 Socket - UDMA100, Serial ATA-30...
White box Intel DQ35JO is sometimes very slow, especially around log in time (It is a member of a Win2k3 domain). Being an intermittent issue does not help. Burnin Pro was unable to locate any problems, likewise the Intel Hardware monitor (which has reported just one problem, but gave no description at all). Nothing seems to indicate any problems. Any ideas - I am wondering if there is a network problem but tests to date indicate that all is well there too.
blulite111
  • 56 Answers
SOURCE: IntelĀ® Desktop Board DG31PR application error
hi sir i think that there is an incompatibility problem or have you tried increassing the RAM?
Posted on Dec 10, 2008
florin_decad
  • 203 Answers
SOURCE: VIA/S3G UniChrome Pro IGP drivers and realtek ac97 driver problem
http://global.msi.com.tw/index.php?func=downloadindex
go there .
Posted on Feb 05, 2009
marketex
  • 371 Answers
SOURCE: Hardware Monitor not working- Intel D945GNT
Not sure what chip you are using, but your problem is one which I have had and solved by the most extreme heat dissipation methods possible...I even went to the extremity of packaging dry ice in Plastic and using an external fan to literally produce arctic temperatures inside the case.
It did attenuate or reduce the heating problem and the Intel hardware monitors took note of that, but I also notice some degradation in the extent of the graphic presentation of the on screen diagnostic display of temperature, fan speeds, etc.
So, with your new problem, since you apparently responded to the three long beeps by adding a keyboard or other peripheral, and solved it, a full statement of that problem with all specs would be appropriate, unless you can no longer read the display.
Posted on Mar 28, 2009
greg_margo
  • 1959 Answers
SOURCE: Ver, very SLOW when booting up! Sometimes the
BIOS System defaults are best used for installing a new operating system or performing diagnostics. Bootchecks and memory checks due to settings on antivirus/antispyware programs are notorious for causing slow boots. In most cases these scans are unnecessary. Saying that, it is also possible you have acquired a trojan. Run a full system scan and if you have a clean machine, disabling the bootchecks and memory checks will speed up your booting. If after doing this your boots are still slow, tweak your BIOS as follows per Intel:
  • Set the hard drive as the first boot device in the boot order in the BIOS setup (Boot > Boot Device Priority menu).
  • Enable Intel® Rapid BIOS boot in the BIOS setup (Boot menu).
  • Disable Hard Disk Pre-Delay in the BIOS Setup (Advanced > Drive Configuration menu).
  • Disable system functions and features if you do not need them. Examples include:
    • Legacy USB - this must be enabled if you use a USB keyboard or USB mouse outside the Windows* environment (Advanced > USB Configuration).
    • Unused I/O ports, such as serial, parallel and IEEE-1394 ports (Advanced > Peripheral Configuration menu).
    • Event logging (Advanced > Event Log Configuration menu).
    I hope you find this solves your problem. All the best! Greg
Posted on Nov 10, 2009
  • 506 Answers
SOURCE: pc problems..the monitor not come on + booting is slow at times
Try an aftermarket video card or possibly flash your bios with the most recent REV. If you get a new vid card disable the on-board VGA and boot from PCI
Posted on Dec 20, 2009
Tip
Intermittent Sync and you: What does it mean?
Intermittent sync is the signal from your DSL, Cable, or Fiber service provider's Central Office (CO) to you losing connection every now and then. Now, with DSL, this also includes low bit rate (where the modem throttles the connection to try and maintain the connection), intermittent route (you can't get online if there is no signal!), and slow throughput/ packet loss. <br /><br />With Fiber, it can mean a damaged fiber optic cable, or potential area outage. <br /><br />Cable does not usually experience low bit rate/ intermittent sync like DSL, however it does have some similarities since Cable does run (at least a portion of the cable!) on copper cabling. <br /><br />Intermittent Sync can be an area issue, however usually area issues are no sync or no route- not the intermittent problems<br /><br />Now, an intermittent issue is hands-down the most annoying of connectivity problems since sometimes it works, sometimes it does not. <br /><br />How do you troubleshoot intermittent sync? <br /><br />Depending on your connection type, you may need to isolate the connection. What this means for DSL is if you have a phone, a fax, and a credit card machine on the same telephone line, you need to see if the intermittent issue clears with those devices off the line. Other factors for DSL intermittent sync is distance from the CO, age of the modem, issues on the line, and problems within the CO<br /><br />If you have noise on the line- it could either be the modem or something within the cabling or CO. <br /><br />With Cable, isolation is not so much of an issue- although they may ask you to remove the cable boxes temporarily till they can verify the issue is not interference from a defective cable box<br /><br />Fiber (FIOS) is unique that intermittent sync is not really caused by issues w/ the wiring of the building- report to technical support immediately if you have intermittent connection issues with Fiber.<br /><br />All of the above issues need you to contact tech support when you have time to do basic troubleshooting steps. However some legwork can make this process easier.<br /><br />Write down when it goes down- if there is a pattern to when it goes down, it can help narrow down WHY the problem is occurring. For instance, a person had service go down after 9am every day and when it was raining. The issue was caused by construction breaking the underground cable casing- and after the sprinklers ran at 9am sharp- the water would get into the casing and short the person's connection! <br /><br />A log of what happens with the problem not only helps you- it helps you help the technician! If you can pick up on the pattern- it narrows the possibilities of what's causing the issue. Any way of narrowing down the problem means you will have your service restored that much faster.<br /><br />If it requires multiple repairs- that log will also help in narrowing down what's left<br /><br />For packet loss/intermittent route- record what sites have the issue and when. Again, the pattern helps troubleshoot the problem.<br /><br />Do not demand for a technician at the location- often the problem could be in the CO- sending a tech only delays getting to the right spot to fix the problem<br /><br />If your connection goes down- the MOST important thing to do: Report it. With intermittent issues, the more documentation, the better. <br />
on Jan 09, 2011 | Computers & Internet
Forgot password to get into windows
When I forgot Lenovo Windows 8 password, I got Windows Password Recovery Tool Ultimate to support me make a password reset disk with USB and reset password efficiently!
Apr 30, 2010 | Computers & Internet
Domain not available I want to log on to my laptop. How do I change domain
click the box under the username and select XXXXXX(This Computer) "XXXXXX" for your computer name. This should log you in locally to the computer. Important to note: You need to have the same username locally as you do on the network. Most are set up this way, but not always. Good Luck!
NOLA Tech
Feb 02, 2010 | Dell Latitude D610 Laptop Computer -...
Win 2003 server install on Intel Desktop DQ35JO Board
I think that you want to take it to workshop when this problem of your motherboard
Jun 28, 2009 | Intel Computers & Internet
Windows cannot connect domain either domain controller is down or otherwise unavailable or because your computer was not found
The resolution and workaround to solve the error is as below.
  1. Login to the Windows 2003 domain controller, and delete the computer account object from the Active Directory by using Microsoft Management Console (MMC) which you can always access from “Manage Your Server”.
  2. Log-in to the PC workstation as local administrator. If you cannot logon as local administrator, try to unplug the network cable and logon to the computer by using a domain administrator user that used to logon on the PC before, by using cached logon credentials feature.
  3. Go to Control Panel, then click on System icon, then go to Computer Name tab.
  4. Unjoin the computer from the domain by clicking on “Change”. You should see that Domain button is now selected. Remember your domain name in the text box. Select (Click) on “Workgroup” to remove the computer from the domain, and put any workgroup name in the text box (e.g. workgroup).
  5. Click OK to exit.
  6. Restart the computer (optional)
  7. Go back to the Control Panel, launch System properties and then go to Computer Name tab, and click on “Change”.
  8. Rejoin the domain by uncheck the Workgroup button and select (check) Domain button, and put in the domain name noted above into the text box.
  9. Click OK to exit.
  10. Reboot the PC.
This should solve the unable to logon to domain error, without changing or losing the user profiles on AD.
Dec 18, 2008 | Microsoft Windows Server Standard 2003 for...
Disjoin SS4000-E from active directory
If a computer is a member of a domain you need to logon using the local administrator account to change the name.
Another method, which takes a little more time is to remove it from the domain, rename it and then add it back.
Remember to restart after each change.
You may also have to go into DNS and WINS and make sure that the old name is removed and the new name is associated with the IP address.
If this helps please vote for my solution.
Aug 29, 2008 | Intel SS4000-E (SS4000ENA)
Domain\administrator has no local admin rights
You may need to edit group policy if this was once in a domain. You may want to try rebooting the machine and logging into the 'LOCAL' machine and see if you have rights that way. Each machine by default has one administrator account but if the server was part of a domain, that right may have been removed. You may need to reset OWNER privileges for all files in the machine.
Jul 24, 2008 | Microsoft Windows Server Standard 2003 for...
No working drivers for Belkin f5d7000 on win2k3
Most drivers for any software or hardware are usually only backward compatible so many "back" versions and will not be supported and can not be guaranteed by any company.  That is simply a "fact of life" with all products in the computer industry.
Time to update your win2k3 machine to the newest and latest.  We all have had to do it at some time or other.
Oct 20, 2007 | Belkin (F5D7000) 802.11g/b Wireless...
Intel Desktop Board DQ35JO - Motherboard - micro ATX - iQ35 - LGA775 Socket - UDMA100, Serial ATA-30...  Logo
167 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
