Question about True GDM-26 Refrigerator
I have a GDM-26 and it has stop cooling, I cleaned out the coil and both fan are working. Could this be the thermostat?
  • True Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 30, 2010
Ajust temp on true gdm 26 f
Hello Tam;
My name is Peter. I am a retired field service refrigeration technician.
The following manual link has the instructions to adjust your temperature. You may also have a bad fan or thermostat.
http://www.truemfg.com/assets/InstallationManuals.../GDM/gdm_english.pdf
Jan 24, 2015 | True Refrigerators
My true GDM-26 never shuts off and my drinks are frozen?
Faulty thermostat, the thermostats are cheap and wear out easy
Aug 15, 2013 | True GDM-26 Refrigerator
I have a model GDM-26. It's was blowing really cold, 30 degrees, then warm, 50 degrees, alternating between the two. Now it's not blowing cold at all and the coils on top do not get cool/cold. Both...
The way you described the problem, I would be looking for a refrigerant leak... I think that it was low on charge and now it is so low that it will not cool at all...
Have a tech. find/fix the leak and recharge the unit...
heatman101
Jun 29, 2011 | True GDM-26 Refrigerator
True gdm 26 no longer cooling. Internal tem 80 degrees, Condensor fans running, Coil is not showing any frost or icing. Removed cover and cleaned coil and removed dust and dirt. Went out "all of a...
sounds like the compressor is not running. The condenser fans are located at the compressor. The fans in the conditioned space are the evap fans. A refrig usually does not have any device controlling the evap fans, they are to run 24/7. Freezers have other controls. Start there and let me know if I can help further.
Nov 20, 2010 | True GDM-26 Refrigerator
Thermostat does not go below 55 degree could it
You should clean them condenser coils and check the fan motor. That is something that is fairly easy to do. Get some coil cleaner from ace hardware and go by directions. Check that fan motor. If it ain't going while the compressor is going that is your problem.
Jul 05, 2010 | True GDM-7 Beverage Cooler
TRUE GDM 26 merchandiser has sealed lines to the freeon and cant access. The fan blows warm air and all the lights work. It just doesnt cool.The compressor was cleaned only 2Xs in 3 years.
What do you mean the compressor was cleaned. It sounds to me you need to clean out the condenser coil. free it from all dust and debris. + Does the compressor work and what gas is in the system, does the condenser fan work. I'm assuming that when you say the fan works, it is the evaporator fan inside the cabinet working. You will have access the condenser fan either from the front or rear of the unit. The condenser unit is normally extracted from the rear. it should slide out but take care not to kink any of the pipework.
Apr 17, 2010 | True GDM-26 Refrigerator
I have a True GDM-26. The contents get cool inside but not cold. The temperature dial is set at the coldest setting. Also, there is a lot of condensation on the bottles inside the cooler. Any...
I have same problem was told condensing fan not working properly. Easy to see if this is the problem, take out guard in front of machine and put a fan blowing into it. I went to home depot and bought a tornado fan and it cools again. Now if I can only figure out if its the fan or whatever contros its speed. If anyone knows how to check please respond.
Nov 24, 2009 | True GDM-26 Refrigerator
Have a true ttp67 that freezes when turned on after 2-3 hours instead of cooling!
If it was off over night the fan comes on you should feel air coming from the inside vent the condensor fan may be bad or the blade is loose
If you feel air then it freezes it's a Classic example of low freon gas.
Oct 02, 2009 | True GDM-26 Refrigerator
Fan works, just stopped cooling TRUE GDM 26
there is a leak of gas in the system,must see where the leak is, repair it then fill the gas,
Aug 21, 2009 | True GDM-26 Refrigerator
We have a GDM-26 commerical coke machine. Only
If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
Jun 08, 2009 | True GDM-12 Refrigerator Commercial
True GDM-26 Refrigerator Logo
181 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
