Question about Haier Refrigerators
I need to reverse the swing of my haier fridge door,but can't see how to remove the handles
SOURCE: door removal
on my trio the handles slid up with a bit of force and then pulled off to reveal screws.
Posted on Oct 27, 2007
  • 8 Answers
SOURCE: can't get the refrigerator through the door ; how to remove handl
When I brought my side by side home,I had to remove both doors. I also had to remove the entry door AS WELL as the door center jamb!! Removing the refridgerator doors is really not a major task!
Posted on Nov 20, 2008
aborcass
  • 2651 Answers
SOURCE: How to reverse door on kelvinator fridge?
Im unable to look up htat particular model number for you, looks like my FRT18, which is made by the electrolux company, in which case, YES you can easily switch the door swing form one side to the ohter, whats on the left goes to teh righ and right to the left, not a problem
Posted on Jan 11, 2009
dragonsthatk
  • 547 Answers
SOURCE: Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Posted on Feb 11, 2009
  • 103 Answers
SOURCE: Outside door handle loose - how do I remove inside panel to tighten handle?
Hi: I hope I'm not wasting your time. I don't recognize your brand of frige as it has symbols on it. But I've never heard of having to remove the liner to get the handle off. Check your manual or look online. I've seen High end friges that use a card to release the handle or require a nudge straight up. I'm sure you checked for small holes in the handle that require a hex wrench to release. Good luck, Jeff
Posted on May 31, 2009
How do you reverse the door
If its a side by side like the one showing on your post, I doubt you can unless there is a spot showing for under the door, and the water and electrical lines are long enough to switch.
Mar 28, 2016 | Refrigerators
HOW DO YOU CHANGE THE DIRECTON THE DOOR SWINGS?
Remove bolts that hold both doors, make sure to remember order, bolts for doors should be universal, but hinges need to go in same place just turned around. On the other side of fridge you need to remove plugs where bolts from otherside go. Install as reverse of removal, leave bolts loose to leave for adjustment. Install refrigerator door before freezer. Then move handles, small covers hide the screws on face of doors others should be exposed.
Jun 03, 2014 | Roper RT21AKXKQ Top Freezer Refrigerator
How do i fit the door on the other side
If you look at the opposite side of your refrigerator, you'll find one or more plastic covers which can be removed to expose mounting holes. You have to remove the doors from the current mounting position, remove the hinges and transfer them to the other side, install the doors and you're done
Jan 25, 2013 | Bosch Classixx KGV28323 Bottom Freezer...
How do I remove ge GBS20KBPACC handle for reverse door swing
You just grab the handle with both hands and pull/lift up like your trying to lift the fridge wirh the handle. It should disengage and then pull off.
Mar 30, 2012 | GE Refrigerators
I have whirlpool A CLASS fridge how do i reverse the door
  • I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
  1. You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
  2. There are some little clips that hinge the screws on the top and bottom of each handle.
  3. Remove these little covers with a small flathead screwdriver.
  4. Now remove the screws holding the freezer and refrigerator handles on.
  5. Now pop the screw hole covers on the side of the frig/freezer you will using.
  6. Now place and fasten with screws the handles on the other side of the frig/freezer door.
  7. Now remove the top freezer hinge first by removing the 3 screws on top.
  8. Now pull up on the hinge (save the spacer).
  9. Now pull up on the freezer door.
  10. Now remove the screws on the middle hinge.
  11. Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
  12. Now pull up on the frig door and set to the side.
  13. Now remove the screws on the bottom hinge (save the spacer).
  14. Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
  • The switch
  1. Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
  2. Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
  3. Fasten the middle hinge.
  4. Place freezer door on the middle hinge.
  5. Put the freezer door in it's natural position to make putting the top hinge on possible.
  6. Screw the top hinge in.
  7. Job complete.
Regards, Tony
Apr 30, 2011 | Whirlpool Refrigerators
How to remove doors of a whirlpool 6vmw47 top mount fridge/freezer
Hello Hicherringto,
I understand that you would like instructions on how to remove the doors on your fridge. Most common on top mount freezers/fridges you need to start at the top and work your way down.
1. Locate the freezer hinge top part where the door swings.
2. Remove the plastic cover over the henge. (top of the box if covered)
3. Remove the screws holding the henge in place.
4. Lift up on the henge
5. Open the freezer door and lift up (the door should lift off the bottom pin)
6. Open the Fridge door and remove the screws from the hinge that the freezer door sat on
7. Remove the hinge from the fridge door by lifting up
8. Open and lift up on the fridge door
9.Reinstall in reverse
That is the easiest way to remove the doors on a top mount freezer fridge. Note that when you reinstall the doors you will have to adjust the hinges so that the seals seal properly. The hinges have enough of a grove that you use them to adjust the doors.
Thank you for choosing FIxYa.com
Justin
Apr 16, 2011 | Whirlpool Refrigerators
I was given a Whirlpool ET1FTK 20.8 cu ft refrigerator/freezer. Door frame going thru is 29 inches. Need to take off doors of fridge to get in house. Anything you can send me. Don't have any of the books...
Start at the top and remove the hinge (5/16 socket). Slip the door off and remove the center hinge. Slip the lower door off and remove the lower hinge. Now is the time to reverse the door swing if it needs it. Move the handles to the other side and reassemble with hinges on the other side if you do.
Eric
Nov 03, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
Jan 11, 2009 | Refrigerators
Jun 25, 2008 | Kenmore 64702 Top Freezer Refrigerator
Refrigerators Logo
132 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
