Question about Casio fx-300ES Calculator
When i divide it gives me the answer in a fraction instead of a decimal, how do i change it so it will give me a decimal every time?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Press SHIFT MODE 2 to select LineIO mode.
Posted on Aug 30, 2010
It is showing fractions instead of Decimals when i do equations like (4 divided by 9) it gives 4/9 instead of the decimal.
Calculation results will be displayed using
fractions, r, and ?. When you press CHANGE, the display will cycle
through the following display styles:
• Mixed fractions (with or without ?) ? improper fractions (with
or without ?) ? decimal numbers
• Proper fractions (with or without ?) ? decimal numbers.
Feb 03, 2011 | Sharp ELW535 Calculator
I have the sharp model EL-W535. When I divide not whole numbers for example 9 divided by 5 they come up as fractions instead of decimals and i can change it from fractions to decimals but it's very time...
To change from fraction to decimal, all it takes is a keypress. (change key)
.Not all decimal results (approximations) will be converted to fractions.
Anyway, if you want to set the calculator to display decimal results only,
Press SETUP
Press 2:EDITOR
Select 1:LINE.
Jan 30, 2011 | Sharp ELW535 Calculator
When I divide the answer is in fraction form not decimal form how do i get it back
There are two options.
1) Whenever you want the answer in decimal form, place a decimal after at least one of the numbers.
For example: instead of using (1/2) use (1/2.)
2) Press the "Mode" button. Scroll down the list that appears until you find "Exact/Approx". If you set it to "Approximate", then it will always give the answer in decimal form. If you set it to "Exact", it will give the answer in fraction form.
Nov 12, 2009 | Texas Instruments TI-89 Calculator
I ask a dividing question like: 8 divided by 10, and it gives it in a fraction how to I cheange a setting so it gives the answer in a decimal?
If a number is displayed as a fraction or a radical (square root or other roots) you change it into a decimal number by pressing the [S<=>D] key, just above the red [DEL] key.
If you do not care for fractions or radicals, you configure your calculator to display only decimals. To do that you press [SHIFT][MODE][2:LineIO].
Warning: If you do that you will not be able to enter fractions or radicals in the natural (textbook display)
Another way to display a fraction or a radical as a decimal is to press [SHIFT][=] to get the result not the [=] alone.
Hope it helps.
Nov 11, 2009 | Casio FX-115ES Scientific Calculator
Say for instant i wanted to do a promblem 75 divided by 100 = 3/4 i want change answer that is a fraction to a decimal i can the answer clear
75/100 [=] gives 3/4. Press [S<->D] key to convert to decimal 0.75
0.75 [=] gives 0.75 Press [S<->D] key to convert to fraction 3/4
It can convert radicals into decimal and decimals into radicals.
Hope it helps.
Sep 28, 2009 | Casio fx-300ES Calculator
When I try to divide numbers that would leave a remainder like 1 divided by 6 which should give me an answer like 0.16666666666 instead all it says for an answer is 1/6. it does say in the manual to input...
To convert from fractions to decimals, and from decimals to fractions use the [S<-->D] key. If you want your decimal results to have a fixed number of decimal places press [SHIFT][SETUP][6:Fix]. Screen shows Fix 0~9. Enter the number of decimal places exemple 3.
Dans ce cas 1/6 is displayes ase 0.167.
Hope it helps.
Sep 23, 2009 | Casio FX-115ES Scientific Calculator
Problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
Jun 01, 2009 | Casio FX-115ES Scientific Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Fraction problem
Go into MODE to the second page.  In Exact/Approximate, change it to Approx instead of Auto or Exact.  This will give you decimals instead of fractions.
Nov 17, 2007 | Texas Instruments TI-89 Calculator
Casio fx-300ES Calculator Logo
42 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
