Question about Fisher and Paykel DEGX1 Electric Dryer
Someone put a crayon in my dryer and it got under neath the part that turns the clothes in the dryer, I was wondering how to take them out and clean underneath, There are no screws visible. Thanks, Linda Simmons
    President:
  • 3,074 Answers
There should be screws inside the dryer door, maybe two no each bottom corner. Gently pry top corners up and they will separate from top, then remove front panel, your dry door switch will have to be unhooked and then just set it to the side. Safety first unplug machine first thing then take apart. Hope this helped Tim
Posted on Aug 30, 2010
HOW DO I remove red crayon stain and residue from the dryer drum. Gramma did the clothes and forgot to check the pockets
The stain may be permanent, but the first priority is to remove all of the crayon residue. Crayon is wax based, so anything that dissolves or softens wax will help remove it, but be aware that some of these things are flammable [like paint thinner] and somewhat toxic.
First thing I would try is Zep Purple degreaser. It is a concentrated version of the same active ingredient in Fantastic but it isn't flammable. Use rubber gloves and a non scratch scrub sponge.
shopping?q=tbn:and9gcruq4dnmzvxkf6uacguphcu4k8-a4m09udguuypngs7c-rs7ta9&usqp=cay
Showing Results for zep purple
Try diluting it about 2 parts water to one of the concentrate at first, if that doesn't work try adding a little more concentrate. Full strength may take the shiny finish off of you dryer drum.
You probably want to use a face mask while using it; get one for paint odors or organic vapors.
3M Tekk Paint Odor Valved Respirator 2 Pack
You should take off the vent hose and try to get as much of the crayon out of the vent passageways.
If the degreaser doesn't work try orange oil cleaner
If the orange oil cleaner doesn't work, odorless paint thinner may, but it will have to dry first and you will have to make sure you have all fumes out of the dryer before using it. Put a fan on the open dryer for 8 or more hours.
After you get it as clean as you can, run a few loads of things that won't matter like work clothes or jeans.
Feb 06, 2015 | Dryers
A crayon was left in pocket of clothes. the garment was washed and dried in the dryer and thus we have crayon dye on the clothes that we can`t get out.
Hi and thank you for using fixya:
I suggest that in order to get the crayon stain out you use kaboom stain remover. It is very strong and works for me on stains, you can get it at your local supermarket.
Thanks
Mar 10, 2011 | Health & Beauty
Drum turns slow since kids left cayons in there clothes
The wax from the crayons likely has got on the outer surface of the drum and on the drive belt. FIRST - disconnect or shut off the power. 220V bites really bad!
You will need to open the dryer up so you can get at the drum, as well as the belt and pulleys. Clean the metal parts with varsol or paint thinner. You can try cleaning the belt with the same but it may be damaged by the solvent. Alternatively, buy a new belt.
Apr 10, 2010 | Frigidaire GLER341A Electric Dryer
Frigidaire FDE336RES2 Dryer marking Clothes
Excessive lint on or near the heater coils will send smoldering lint onto the clothes. Use a flash light and go inside the drum to see the heating coils or lifting the top up who should be able to see the lint build-up on the coils. These need to be cleaned.
Nov 10, 2009 | Dryers
Dryer is leaving black marks on cloths.
was a pen or crayon placed in the machine by mistake ? You will need to
remove the residue, use rubbing alcohol on a rag for marker or pen ink , crayon use a razor scraper and then clenser and scrunge pad.
Oct 26, 2009 | Fisher and Paykel DE06 Electric Dryer
How to clean black marks left in dryer from shoes
I had used a little nail polish remover on the marks when this happen. Then I wiped it out with a cloth after I was through doing the dishes ( had dish detergent on it) and a rinse cloth and dried. I then always let the shoes/boots air dry or you could put them in a pillow case to dry. Good Luck!
(You should have seen the mess I had with a melted blue crayon one day!) Got that out too-but it took me a while.
Oct 21, 2009 | Whirlpool GGQ8831L Gas Dryer
Help getting crayon out of dryer.
If they are globs you can freeze them by rubbing with an ice cube and scrape them off. If the residue is thin like a coat of paint use denatured alcohol or paint thinner to rub them off. Make sure you leave the dryer door open several hours after using solvent inside to air it out. Do not use the dryer immediately after using solvent or there could be a fire hazard.
If the crayon residue is on the clothes, you can put piece of absorbent paper (like a paper grocery bag) over the stain and iron it. The heat will melt the crayon wax and the paper will absorb it. You may have to do it several times to get it all out. Denatured alcohol or paint thinner might be needed to get the final stain out.
Jun 29, 2009 | Dryers
Orange crayon melted all over the drum of drier and I cannot get it cleaned. Any suggests?
You now have hot melted wax coating EVERYTHING, I bet.
First, unplug your dryer, for safety.
Now take some turpentine or wd-40 and dampen a cloth with it.
Scrub, scrub away.
once it's clean(will take a LOT of elbow grease), you'll want to clean up the solvent.
A wash-cloth, dampened with soapy water, will do a pretty good job here.
Finally, leave the machine OPEN for a good solid day/night.
This lets any fumes remaining from the solvent escape.
this is important, if you don't want to blow up your dryer when you next start it up.
Jun 01, 2009 | Whirlpool Dryers
Dryer
nothing in the dryer i.e.crayon left in pocket?? there is no black grease used in the unit only White lithium style.. I dont think it came from the inside of the mach ...Best bet is to clean the tub out mild soap and a damp cloth it should go away. if not the peice maybe stuck in the baffles manually spin the drum do you hear anything rattling around?? Let me know
Jan 26, 2008 | Dryers
Fisher and Paykel DEGX1 Electric Dryer Logo
75 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
