MY AIR CONDITION IS BLOWING ONLY HOT AIR. I HAVE NONEYWELL TH5220D1029
  • 828 Answers
Http://customer.honeywell.com/honeywell/ProductInfo.aspx/
TH5220D1029#LiteratureDownload
This URL will allow you to select your model number and download the instructions.
Posted on May 08, 2008
My air condition is blowing hot air the day b4 it was blowing cool air could that be the compressor, or the climate control what could I do to fix it cant afford a lot of mechanical work
I can think of at least a dozen things that could cause that. But when you keep the year, make, model a secret, it's much harder to give any kind of answer
Sep 03, 2017 | Cars & Trucks
My ac is blowing out hot air
Get your ac recharged. Can go to part store and get get a can of freeon and do it yourself.
Apr 28, 2016 | 2005 Cadillac Escalade
Air condition is blowing hot air
low Freon sometimes the front seal on ac compressor goes bad take it to a shop they should have a leak censer to find the leak
Aug 17, 2014 | 2005 GMC Yukon
I am looking for the two circuit boards for the Sharp Portable Air condition Model CV-P10NC
These units are not economically viable to try such repairs out of warranty.
Mar 15, 2013 | Heating & Cooling
Why does fan not cycle off on heat cycle for TH5220D1029 thermostat
1) normally you must to exchange by new batteries with the same types alkalines FULL charges.
1a) see if there are some wires loose and tight it
2) reset and program it again , follow the instr. manual if you do not have download from Honeywell from section support give the number, model and do it.go to http://yourhome.honeywell.com/home/
God bless you
Oct 08, 2012 | Honeywell Th5220d1029 Non-programmable...
Lincoln lse 2005 ac blowing hot air on left side!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If your LS is blowing hot air on one side of the dash and cold on the other the problem most likely is the Dual Coolant Control Valve. The DCCV is used to control cabin temperature. This valve is mounted down low on the passenger side of the radiator fan shroud, and has 3 coolant hoses connected to it. This valve if found to be faulty will need to be replaced to correct the condition.
Jun 23, 2009 | 2005 Lincoln LS
Air condition
start with charging the system with r134, be sure to check the pressure before charging
Aug 03, 2008 | 1994 Isuzu Trooper
Heating & Cooling Logo
202 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
