Question about Smoothfitness Smooth Fitness 675 Folding Treadmill
Potential roller bearing problem. Treadmill (Smoothfitness 9.25HR) makes clunking noises.
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: my smoothfitness 5.25 treadmill is stuck in the
Unplug your unit take the motor shroud off and you will see a circuit board (Motor Control Board) their should be L E D s on the board. Now plug your unit in and you will see these light up if you have a second pair of hands that can help you have them press you incline controls.
You should see one of these L E D s light up followed with a click of a relay this activate the incline motor some of these boards will have a 3 amp fuse to protect the board from damage , if you see a open fuse replace it with the same exact fuse. If it blows again either you have a shorted armature winding or the worm screw is frozen. I would call Smooth Fitness, depending wiether this was made by either Sports Art Fitness or Keys Finess they will direct you to theproper parties.
Posted on Mar 11, 2010
Front end clunking noise
Usual cause is roller bearings. Try to oil them they are probably rusty at worst you will have to replace roller. But this is as very good machine. Good luck
Jul 06, 2014 | Precor Exercise & Fitness
Nordictrack 3700 makes a knocking sound when I run on it
Hello.
Knocking noises more than likely come from the rear roller, there could be a small chance it's coming from the motor it's self though.
Have some walk on the machine and make the noise while you locate which end of the treadmills coming from.
If it is the rear roller the bearings will need to be replaced, this can be done by removing the rear roller and taking it down to any bearing shop and have them locate the bearing numbers. Ask them for advise on removing them as well.
If the noise is coming from the front of the treadmill then have a look at the fly wheel coming off the motor, locate grub screws and tighten.
GymWorld.net.au
Jan 11, 2014 | Nordic Track Nordictrack Track E 3700...
There is a tapping noise when I run the treadmill
hi,
if you didn't lubricate the treadmill the try to do that first. if treadmills are not properly lubricated in time they will make noises and will cause problems for running belt and motor . check the video to know how to lubricate the treadmill.
if you would like to know more about treadmill regular maintenance then check the link bellow.
Treadmill regular maintenance
Oct 27, 2013 | Body Sculpture Bt3152 Motorised Treadmill
Escessive noise in rear roller
see the video attached, lube the rollers bearing front +and back too.
test the drive belt motor, replace the belt if necessary.
If the problem persist, replace the old board deck belt.
God bless you
Oct 14, 2013 | Smoothfitness Exercise & Fitness
Landice executive L8 treadmill makes clunking noise when I run on it
You need to get someone out to look at it. Noise issues are rarely able to be diagnosed remotely.
Mar 21, 2013 | Landice L8 80 LTD Executive Trainer...
Loud clunking noise in rear roller of proform 580 treadmill
You must LUBE the deck belt first, this happen because you do not lube maintenance schedule, Do it every week from use.Maybe you have a WORN deck belt.
2) LUBE the rollers bearing front and end, use WD-40
3) Test the drive belt motor, for cracking or worn, and replace.
God bless you
Nov 29, 2012 | Proform XP 580 Trainer Treadmill
Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
Jun 10, 2010 | Horizon AFG 5.0 AT Treadmill
Runs okay but is starting to make loud sharp clanking noises
Clanking sound is bearing that has gone bad in a treadmill, unplug the treadmill remove the motor shroud. Use a long handled screwdriver and touch it to a non-moving portion of the front and rear rollers and motor and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding or clacking noise of the bad bearing with be amplified by the screwdriver
May 23, 2010 | Dmm Vision Fitness T9500 Treadmill
The rear roller appears to be making noise as if bearings are going bad. Is there anything to replace or grease?????
Pretty much the bearings have flatten if you are getting a clunking sound these are normally sealed bearings and it is better to replace the roller. Call Icon Fitness @ 1-800-999-3756
Apr 09, 2010 | Reebok 8700 ES Treadmill - Silver Service...
Smoothfitness 7.1hr would not run
Sounds like the motor is stuck or bad. Get into the front panel near the roller and remove that cover and check it with a volt meter
May 16, 2009 | Smoothfitness Smooth 5.45 Folding...
Smoothfitness Smooth Fitness 675 Folding Treadmill Logo
Top Smoothfitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Smoothfitness Exercise and Fitnes Expert? Answer questions, earn points and help others
