Hoover 'Vision' 816 1 80
Door Not Closed Caption illuminates, only cancelled by firm 'thump' on front or 'slam' of door.
    Genius:
  • 1,073 Answers
Replace the door switch
Posted on May 08, 2008
When the machine is switched on there is a clicking sound from the door and the machine won't start. Opening and closing the door and giving it a thump, works after 2 or 3 attempts. Is the problem
Had a similar problem with our Kenmore front load washer, our grandson was caught leaning on door while it was open and it bent the hinge slightly, this misalignment resulted in the latch mechanism trying to lock the door shut( needed as a safety measure to prevent leakage) but it was unable to do so. Had limited luck with lifting the door while shutting it and holding it closed while pushing the start button,but eventually had to replace hinge. Parts man at service desk also advised not to hang wet heavy items on door (don't know why anyone would want to) as the same thing could happen,also don't try slamming door as that could result in costly latch replacement. Hope this was of some help
Feb 24, 2013 | AEG Lavamat 74640 Front Load Washer
Hoover vision hd 8kg door security button flashing
i now have same problem- did you get a solution?
Feb 17, 2012 | Hoover Washing Machines
Indesit wil 153 door red led is flashing after I set washer settings, doesn't start cycle ?
The flashing light means that the machine thinks the door is not closed (The door lock switch is not activating). 99% of the time this is simply a sticky switch and the solution is to give the door a good firm slam shut (Don't get silly here, but it will take a pretty good "teenager slamming the bedroom door in a temper tantrum" type slam).
In the event that this doesn't work, then you're looking at a faulty door interlock switch. They're not that hard to obtain or fit if you're fairly confident. Drop me a comment back here and let me know how you get on. Happy to help further if the above hasn't allowed you to solve the problem.
Aug 15, 2011 | Indesit W 123 Front Load Washer
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Apr 24, 2011 | Hoover Washing Machines
My Hoover 1600 AAA Vision HD 8 kg. Washing machine will not open the door after programs are ended. I can run all programs, but when finished the door will not unlock! What is wrong? I dont have the...
try pushing the door really hard if it opens check the door seal is on properly sometimes they pull off when removing clothes they can get trapped in hinges
Jan 17, 2011 | Hoover AAA160 Front Load Washer
DOOR HARD TO CLOSE
need your door lock assy replaced
Mar 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Cannot get washer door to open.
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Creda W120VW Intermittently not starting when door is closed.
I don't know if you are still having a problem with your washer, but a new door lock is needed to put it right.
Sep 09, 2008 | Creda W120VW Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
