My pc monitor screen is shaking due to some reasons, what hould i do?
    Novelist:
    Scholar:
  • 134 Answers
Try the screen on another pc.. Or load a new driver for your video card.. Maybe anti-virus scan.. Or make sure cable is cnnected correctly.. I have also seen bent pins in the ends of video cables.. check that. Rgds,
Posted on May 08, 2008
My Acer 21.5'' wide screen monitor shakes when I
Get a better stand to hold the monitor. There is nothing wrong with the monitor, it's the operator.
Jun 24, 2011 | Acer Computers & Internet
My browser screen / windows explorer flickers infact shakes vigorously, possible virus attack. try to run couple of anti-virus, but not able to detect. what's the solution?
screen shakes ,,,Due to virus..... It's sound's like fun......
May be it shakes due to signals, keep Ur mobile phone or any other devices away from Ur Monitor
I hope Ur problem 'll solve....
Jan 04, 2011 | Computers & Internet
The bottom half of my screen is shaking like a "non" TV channel.... I restarted it, and turned it off and back on again and it continued. The shaking occurs every 2 seconds and is spreading higher now. ...
If you can.. Plug a Desktop Monitor into the Serial Port of the Laptop..You do This To See If It Shows Same Thing Onto A Different Screen.. If It Does, You Are Having Video Issues.. Which Were Most Likely Caused From Overheating Issues..
If It Shows Normal On The External Monitor, Yet Still Does Same THing On The Laptops Screen, Then You Have 1 of 2 Issues... Either You Need To Replace The Display Due To A Faulty Circuit Board On The Backside Of The Screen... Or Your Display Cable Is Loose And Needs To Be Fully Plugged Into It's Port, Or The Display Cable Is Failing..
Nov 15, 2009 | Computers & Internet
How do I find out why my computer screen suddenly started shaking?
Hi, Darleen.
The most common reason is interference. Typically, fluorescent lights, speakers, radios or other devices may be too close to your monitor.
If not, and if your monitor is a CRT-type, rather than a flat-screen, and the shaking is worse when you move the monitor, your monitor would need to be replaced.
Hope this helps.
Sep 25, 2009 | Dell Computers & Internet
Screen shakes BUT menu is clear (Not shaking) and the power cord solution does not work. What other Ideas are there?
Try installing this Monitor on a different PC. If the problem is then resolved, its your video card.
Jul 25, 2009 | Acer AL1716B 17" LCD Monitor
Lg w1934-bn blank screen after start up, power light on . same problem occurs on different computers used.
Reason 1: Wetness The number one reason why computer monitors go blank is - wetness. Believe it or not, when your computer monitor is exposed to humid air, sometimes water can condense and accumulate in the monitor. This causes the monitor to malfunction and go blank. I've had this happen to my desktop PC at least three times before. What you need to do is to leave the monitor alone for some time and allow the water to evaporate. That usually solves the problem.
Reason 2: Faulty Graphics Card The next reason why your computer monitor goes black is due to a faulty graphics card. The best way to detect this kind of problem is to connect up a new monitor to your PC, then check if you have a blank screen. If you continue to have a blank screen, then it's likely your video card is faulty.
Reason 3: Faulty RAM This one is less obvious and less common, but it can happen. You might sometimes get bad RAM modules which prevent your PC from booting up even to the basic BIOS startup screen. To detect this kind of problem is more troublesome, you might need to remove those RAM modules and insert them into another computer.
Reason 4: Loose Connections Another reason why your monitor goes blank is due to loose connections. The connection from the monitor to the mains is usually a culprit, as is the connection between the monitor and the video card. Check those connections before you declare your computer monitor as faulty.
Reason 5: A Short Circuit In The Motherboard And the final reason why your computer monitor goes blank? It's possibly because of a short circuit in the motherboard. This is the most undesirable outcome of course, as you might have to replace your entire motherboard. However, it's possible that this can happen - so keep your fingers crossed and hope it doesn't happen to you.
i think this will help.
please rate my solution.
have a nice day.
Jul 05, 2009 | ViewSonic 17" 1280x1024 TFT-LCD/ Speaker...
My monitor went black, and the power switch just flashes.
is your CPU working properly? if that the case, your monitor is in need of a service.
reasons for why a monitor goes blank?
Reason 1: Wetness
try this.
have a nice day.
Jul 05, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor is just not turning on
anyway read this.
this may help you.
reasons for why a monitor not turning on?
Reason 1: Wetness
try this.
have a nice day.
Jul 04, 2009 | Computers & Internet
Control lock
Temporarily you can -- hold down, while monitor is on and the menu button for 10 seconds (source Samsung faq). This hould unlock the buttons.
This problem is due to abad 7805 regulator ic ora memmory ic
To completely stop this you will have to replace the 5 v regulator
Jun 09, 2008 | SAMTRON 55V 15" CRT Monitor
Shaking Monitor
I had the same problem when I reached in back of my pc and disconnected a web cam from a usb port. Them my monitor started shaking and i thought it was related to the web cam unplugging from the usb. I tried uninstalling my video card driver, and re-installing. Still no fix for the shake. So i tried turning off the monitor, and removing the monitor cable from the back of the pc. I re-attached the monitor cable, and powered on the monitor. Bam! No more shaking, all was good with monitor picture. The problem is, and was, as i unplugged the web cam usb plug from the usb port, i bumped into the monitor cable near where it plugs into the pc port. The problem is that there is a weak solder joint in the motherboard in the video card holder socket. I will need to either find the weak solder joint, and fix it, or replce the motherboard. I have a older dell antique dimension 8100 that i still like. It is the original motherboard and it is from 2002. I know i should replace this old pc, but i have done a lot of upgrades on it, and has been a great old pc. After shelling out over $2,000 for this unit in 2002, i want to keep running it. It does all i need to do. They don't build pc's this solid anymore. I hope this helps someone. Thank you!
Jun 02, 2006 | Samsung SyncMaster 955 DF 19" CRT Monitor
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
