Question about Dell A960 All-In-One InkJet Printer
I have a dell A960 and im getting a cartridge error that say error 50C. What should i do?
    Problem Solver:
  • 11 Answers
Your ink cartridge has a short.
1 Press Power to turn your printer off.
2 Unplug your printer.
3 Plug in your printer.
4 Turn your printer on.
5 Uninstall and reinstall the cartridges.
Posted on Aug 30, 2010
I am getting a 50c error on my dell 960 all in one printer how can i fix this problem
only Dell ink carts will fit or work in you printer. If the ink cartridge you got is a refilled used Dell ink cart. It should print ok but will never indicate true ink levels. If the ink cartridge carrier goes to the left when the clear plastic indexing strip which is attached to both sides of the printer, has slipped out of the slot on the back of the ink cart carrier or the strip has come off of one side. If it is off put it back on. In future use only new dell cartridges.
If this helps please give me a good rating.
Thank you and good luck
Oct 20, 2010 | Dell A960 All-In-One InkJet Printer
I keep getting a cartridge 50C cartridge error on my printer. What can I do to fix it? I can't print just anything. The test printer works but I can't print anything else.
Hi there Error 50c
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 07, 2010 | Dell A960 All-In-One InkJet Printer
Error code 50C
Hi there Error 50c
This is for the Dell 940 but may do for yours aswell.
color cartridge.
Jan 07, 2010 | Dell A960 All-In-One InkJet Printer
Cartride error 50c on display
Hi there Error 50c
ok ok try see if this works
color cartridge.
Oct 31, 2009 | Dell A960 All-In-One InkJet Printer
Error 50c, recieving this error when trying to print or make a copy
Hi there Error 50c
It works for the 940 it may work for the 960 too.
color cartridge.
Oct 07, 2009 | Dell A960 All-In-One InkJet Printer
Says Cartridge error 50C...what does that mean?When the printer is turned on, it flashes this message, but I can't find it in the manual or online.
hi : shunaswim
the error 50 c means either a cartridge fgone bad or the carrrier inside the printer gone bad .,
possible reason ., : having intalled faultly cart . if u got  refilled cartridge ., then contact retailer .,
if got a new cart from dell ., call them @ 18006249896 and get a replacement cause the carts have 2 yr warratny on them ., make sure u call them along with the order # of ur purchase .
most importantly :
u need to know which cart is causin the problem : black or the color .,
try one cart at a time ., if both the cartridges have the same problem ., the n repalce the printer or the cartridges .
hav a gooday !
Jul 27, 2009 | Dell A960 All-In-One InkJet Printer
Dell a940 error code 50c
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
good luck
have a nice day
Jul 08, 2009 | Dell Office Equipment & Supplies
Cartridge error: 50C and Hardward Error: 502
The "clear tape" that you are playing with is called the "encoder strip." A barcode is etched on it that tells the printer carriage where it is. If you clean this carefully (google encoder strip for best methods) you may be able to get rid of 502 error for a while.
Not sure about 50c.
Jan 23, 2009 | Dell A960 All-In-One InkJet Printer
Dell a960 50c error on cartirdge error message ..nothing seems to
Hi there Error 50c
color cartridge.
Jan 17, 2009 | Dell A960 All-In-One InkJet Printer
Cartridge Error 50 C in manual A 960 No l
One solution is to replace cartridge snap-down levers  (the levers that snap down inside the dell printer to hold the cartridges, blue for color and black for black). This seemed to have work for several people with the same issue.
Nov 25, 2008 | Dell A960 All-In-One InkJet Printer
Dell A960 All-In-One InkJet Printer Logo
237 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
