Question about Acer Aspire 5100 Notebook
Hello, I had my hand on the key board and I don't
Hello, I had my hand on the key board and I don't know what I touched causing the screen turns sideway, like iphone. How can I get it back to straight?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
Press the control+alt key and then use the arrow keys to change the view.. Definitely the problem will be fixed....
Posted on Sep 01, 2010
My iphone screen cant touch ?
Hello there,
There are two major reasons that could be causing the touch screen not to be responding. The first is if the phone fell and the sensor board got bad, and the best solution is to replace the sensor board. To replace the sensor board is quite sensitive so i will strongly advice you seek advice from a specialist that can assist you with that. But if you intend to fix it DIY way, then you can ask and i will direct you through the steps.
On the other, it might be the screen is weak and needs calibration. To calibrate the screen. I will advice you go through the user manual for the steps to calibrate the screen of your phone. If you cannot get any response from the screen, i will advice you replace the sensor board. Because calibration requires you to touch the screen and since it is not responding to touch, it will be pointless trying to calibrate.
Thank you for using fixya.
Caseytech
Sep 21, 2011 | Apple iPhone Smartphone
Touch screen is not working, how do i go to menu, shortcut key to menu.
There are no shortcut keys to the menu option except you stored them yourself. But since you o not have any shortcut key to the menu, it simply means you just have to fix the phone.
On the other, it might be the screen is weak and needs calibration. To calibrate the screen depends on the type of phone it is. I will advice you go through the user manual for the steps to calibrate the screen of your phone. If you cannot get any response from the screen, i will advice you replace the sensor board. Because calibration requires you to touch the screen and since it is not responding to touch, it will be pointless trying to calibrate.
Caseytech
Jul 06, 2011 | Samsung SGH-A877 Impression Cell Phone
I don`t know how to change the date and time of my sony dsc-t200
Hello there. You can do it this way:
1 Select (Clock Settings) from (Settings) on the HOME screen. 2 Touch [Clock Settings]. 3 Touch the desired date display format, then touch [t]. The clock settings screen appears. 4 Touch each item, then set its numeric value by touching v/V. 5 Touch [OK]. To cancel the clock setting Touch [Cancel] or [BACK] in step 5.
Sincerely, Steve TM
May 28, 2011 | Sony Cybershot DSC-T200 Digital Camera
.. key board not turning sideways to text it did
  1. Double tap the home button on the bottom of the iPhone/iPod Touch.
  2. Scoll left by dragging from left to right at the bottom of the screen.
  3. Tap the button on the bottom left.
  4. Now your screen lock orientation should be turned off so your keyboard will turn sideways when you turn the device.
Mar 22, 2011 | Apple iPhone Smartphone
My touch sreen will not work i taped on the screnn but it would not work.
The sensor board is not making proper contact with the main board of the phone that is why the touch screen is not working. It might be that the connection is faulty and needs to be replace, or you just need to resit the board properly.
Also check if you do not have your screen locked by any key by the side of the phone, if properly checked, then it means you need to replace the sensor board of the phone.
Take care and good luck
Oct 23, 2010 | Cell Phones
I have dropped my htc diamond (sprint) and the screen does not turn on.
I don't know if this is the same problem I had, but I think it is. I dropped my HTC Touch Diamond (standard version) yesterday and when I turned it on the screen didn't show anything.
I took it apart and found out the problem was caused by loose connectors between the main-board and the lcm- and navi-board.
The main board (green rectangle marks the problematic connectors):
Which connect to (green rectangle):
Hope this helps.
Kind regards,
ScHAmPi.
Jun 26, 2010 | HTC Touch Diamond Smartphone
When i turned on the leapfrog and asked me to log in my name it doesn't let me go in when i press it with the leapfrog pen
the screen needs to be re-calibrated. Do this: while powering on the Leapster, hold down the ? key. If it's been worn off, it's the round key on the left hand side above the t-arrow keys and it's the middle button. A new screen will come up that lists Base Info Cart 1 Info, Cart 2 Info, Cart 3 Info. In the right hand corner is a "A" that you can touch with pen beside it, it says "Touch Calib" Touch on that.It will say starting...then in the upper left hand corner there is a +. touch it with pen. it will move to bottom left hand corner. Touch it with pen. It will move to right bottom corner. touch with pen. It will move to upper right hand corner. Touch with pen. It will move to the center of the screen. Touch with pen. Repeat until you come back to the Base Info screen. You're DONE! Power off and on again and you should be all set! Good luck!!
Feb 28, 2010 | LeapFrog Leapster 2 Learning System
Waste toner
right hand side lower right bottom cover 2 scrrews remove cover bottle behind it . then you need to clear counter in service mode in this order touch add func key then 2 & 8 at same time then add func key again screen should change to serv mode then in this order touch copier / counter/ misc/ waste toner/ clear key/ ok turn off then on
Jan 19, 2009 | Canon imageRUNNER C6800 Copier
Gateway monitor problem
Does this monitor has a reset to factory specs on the menu? If so then select it.
Jan 05, 2009 | Gateway FPD1760 17" LCD Monitor
Cursor skips back into sentece or paragraph
Usually it is just from your hand/thumb touching the touchpad and registering as a single-click causing the cursor to jump back. This is a well known issue with the MacAir due to size/design of the machine and the sensitivity of the trackpad. Many people have found it to be resolved by turning off the "touch to tap" feature, however it is annoying when you need that. Hope this helps you! Happy Hollidays!
-Joshua Childs
Dec 26, 2008 | Apple MacBook Air
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
